hesitant c180
lackofgrip
Close enough
right i have a C180 elegance on a 1998
when the car gets towards 4000, to 5000 revs it seems to be holding back
just wondering what this could be
i have installed the following all brand new
lambda sensor
air flow meter
exhaust
full service all new plugs air filter etc
and still it does it
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Interested to know if it was an ebay purchase!!!, whats to say they dont repair faulty MAF's and pass them out as new!!!!!
jib
kth286
E320 Coupe 95
How many miles car done ? I ask because the fuel filter needs changing at fairly frequent intervals and if partially blocked will reduce fuel flow at wide open throttle and hold you back.
It is under the cover just in front of rear wheel. Has it been changed in your possession ?
mattkh
England
A160 W168 1999 1.6
When was the air filter last changed
lackofgrip
lackofgrip
Close enough
will check the fuel filter.
it was a brand new air flow from gsf in sheffield
star
Reading
Smart + others :)
It might need initializing, or "boot strapping" where the throtle and mixture settings are reset?
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Should be ok as a straight fit. Disconnect the battery first though just to be sure and make sure the keys are in your pocket and not the ignition.
jib
lackofgrip
lackofgrip
Close enough
so just disconnect the battery? to reset how long should i leave it disconnected?
BlackC55
South coast
C43
Another suggestion:
Throttle flap?? The potentiometer insde faults.
lackofgrip
lackofgrip
Close enough
Another suggestion:
please explain?
thats another thing sometimes when i come to a junction or giveway the revs stay at about 1300rpm and drop down slowly or i sometimes have to catch the accelerator
please explain?
A common fault for high idle is the idle change over switch built into the air flow sensor.
The switch levers wear so the it does not close, you can file the levers so the switch does close.
This can be checked with an ohm meter in the socket on the airflow sensor
lackofgrip
lackofgrip
Close enough
  • #18
any pics or diagrams?? im not very good at this type of thing.
could my hesitancy problem be because the throttle is sticking and not opening fully?
I have not got pics as it is not supposed to be repaired, yes the airflow plate can get sticky with the gluey substance, alway worth undoing the screws and cleaning it all
