x AMG x
- Jul 23, 2009
- Age
- 34
- Location
- SUNNY RHYL
- CLK 55AMG (MINE WEN IM 21) GOTA BRAND NEW CLIO 1.2 TURBO
Hi ,
i gota 203 (c class) 220cdi 2004 reg
the fault code is 2641-008 (using the star diagnostics)
the fault is there is no/turbo lag at low revs upto about 3,000 revs turbo is good when you kick down though and after 3,000rpm
it had a non-genuine turbo fitted sum where and i have just fitted a new MB back pressure switch .
any help would be much thanked i personaly think it could be the module on the turbo seeing as it is a non-genuine 1.
ANY IDEA'S PEOPLE ??
THANK YOU .
oh and also it has a particulate filter and im guessing the old turbo had oil leak so there-fore could be blocked but on actual values only on 17% blocked but im not sure if the actual values only counts sutt or if it would know about the oil blocking it ??
cheers people.
THANK YOU .
cheers people.
