Was looking at max 125k but really not finding much so may go a little higher ..If you are looking at higher mileage cars general condition and service history are more important than anything else especially <10k miles oil changes. Mercedes will do high miles but they need to be cared for.
Nice! But problem is not everyone looks after the cars properly like you have done , so always difficult to know if it’s alright or not, unless you know exactly what to look for ..![]()
They’ll cover good mileage if well maintained. Thisis a private hire w212 with om642 v6 diesel. I’ve looked after it from 10,000 miles
So how would you know if the mileage has been changed ? What do you mean by over and above a stamped book? Receipts for work carrried out yes?The engine is reputable but no two used cars are the same. German cars are also easy to clock so be mindful of this, it’s far more common than you think.
Expect to take your time to find the one and appreciate it may not have even come up for sale yet, so patience is also needed.
As mentioned above the more oil changes, the better it is. So called long service intervals only exist for to provide the illusion of low service costs but, help cause premature failures and thus line the pockets of the dealers.
Go to see every car you’re interested in and when the right one comes along you will know as a genuine good one will stand out over the usual average used example. There should be high mileage, low owner, motorway cars knocking about frequently so you can’t really put a mileage figure down to determine what is/is not good.
For me my baseline that’s never ever failed me is;
1. Low number of owners regardless of age and miles. This shows the owner(s) have liked it enough to keep it for a long period of time and therefore it will have also been more keen to look after it.
2. Good external and immaculate internal condition.
3. Matching mid range / premium tyres all round (with the exception of the odd puncture causing a problem where a tyre may not have been available).
4. Fully documented history, over and above a stamped book.
When I bought my Supra, most cars were in the region of 30-60k on the clock but presented as less than fully spot on to me. A few years later I bought one with 147k on the clock but it was cared for it.
Ah, the 646 engine.My 2007 C220 CDI Sport has now covered 280,000 miles and still drives beautifully.
Oil has been changed every 10,000 miles, and serviced religiously. Mercedes recently paid for a replacement rear subframe (quite a common fault for vehicles of this age), but still using orbital exhaust, alternator, injectors (seals replaced last service). Fuel additive regularly used to clean and lubricate the fuel system.
I'm impressed that someone had the fore thought to reset the trip to make it all line up!So much for modern Mercedes, my friends 2015 CLA 220 just passed it’s badge
My Viano has 344000 and is virtually all original, it’s had a water pump, alternator and ac compressor, plus a set of injectors, still runs well although I have an injector seal leaking. The key is clean oil and long runs.Ah, the 646 engine.
If only they were still putting that in motors today.
But not enough revenue for the main agents on repairs, not enough reason to replace to keep a reliable motor.
I sold a Vito with 326k on the same(ish) engine. If my present Viano on it's 651 engine gets near that figure I would be surprised.
