Hood of a CLK 230 (1999)
welshcaro
Hello.
I am hoping to get some advice. I have a CLK 230 Convertible.
Last weekend, from nowhere, the hood would not open. I press the butoon and its as dead as a do-do. Prior to this the hood had been operating normally! No problems, no slow down, no noise.
I took my car to a Mercedes dealer who ran a diagnostic for a bargin sum (not) and they were unable to pin point the problem.
They said it was either the Relay (at a cost of £22) or the Pump (£1500) plus VAT and Labour.
Obviously I am hoping its the Relay, but the dealer says that in order to check, it will take 3 hrs to strip the car down to get at it. Therefore he recommended that the pump be ordered to save on Labour.
For sure I want to avoid Dealer prices for parts and labour. But talking to a friend he cannot understand why 3 hours to locate the Relay.
Has anyone had a similar experience or can offer any guidance. The sun is out, would love to have the roof down but don't want to burn a hole in my pocket to the tune of £2000!
Caroline
Speedmaster
Scotland
CLS 55 AMG
Sounds like an expensive problem
As a fellow owner of a clk cabriolet, that worries me
I can assure you that all of us with tops, hope this will never happen to us.
Malcolm
Speedmaster
Scotland
CLS 55 AMG
I had bmw convertibles for just over 4 and half years and never one problem, same with the CLk since December 05. Hopefully that will continue.
W
welshcaro
clk 230 hood
thanks, i will try! i am determined to find a better way thn the dealer suggests!!
David Williams
Hi Welshcaro - I have the same problem as you had. Did you ever get your's fixed and what was the problem?
AAPete
Kent
I took mine to the MB dealer who quoted me 2.5k and diagnosed the problem as either the contol unit or the hydraulic pump, I took the car to someone else who found a £2.99 relay needed replacing!!
David Williams
You're having a laugh... I hoped you lobbed a brick through the window when no-one was looking (joke)
I have just contacted Parkhams who come highly recommended from the forums and they were most reassuring about my roof problem, indeed they reckon it is highly likely to be a micro switch problem - Won't know for sure until I get down there next week and get the codes - Here's hoping....
Probably the micro switch at the front of the boot, thats the main one that goes
JMH
phew
i just had the same problem. The hood wouldnt open but windows would go down when button was activated. I came on here knowing i would find the solution. I found the plastic cover/roller blind thingy in the boot had come adrift. i taped it back onto the hard plastic cover in front of it making sure the cover was nearly fully extended on its roller and hey presto hood works again. obviously a microswitch in there somewhere. Thanks for the pointer guys :D
sinny
New Registration
Hi All
I have a 2001 CLK 230 Convertible & had it over a year no problems until the weather last week was good & tried to put the roof down! Wont work any suggestions or help the windows go down and the red light is working but ive noticed when i start the car the rollover rear headrests start to flash and then goes out. Not sure if this has anything to do with it.
regards
Sin
