Hope this is the correct thread
loramos
350sl
On an R230what exactly alters when you selct the C/S modes. Honestly not sure I feel any really noticable feel in the cars perfomance . i drive mainly in town and the occaisional long drive 60 kilometers or more two or three times a month. roads here in Spain are pretty good and very few speed bumps in my part of the world.
C (comfort) starts in 2nd gear and changes gear earlier , S (sport) starts in first and holds it in gear for longer
L
loramos
350sl
thanks Wighty .Is that it though ? Doesn't alter handling etc. then?
Just the gearbox as per above. If you have the ABC (active body control) suspension you can alter that separately.
L
loramos
350sl
Thank you both . i normally leave it in S mode so will continue to do so then.
Yes this. C/S is just gearbox parameters.
On ABC equipped cars there's an ABC Sport button that firms up the struts. Body roll is limited to 0.75 degrees (normally 1.25 degrees) and damping rates increase. No such facility on coil spring cars.
Srdl
Hampshire
GLC43 AMG 2018 (X253)
I had adaptive dampers on my previous car and the S button used to tighten up the suspension on that. It depends on what your car has, I suppose. On my 207, it also altered the steering response and made it slightly more fun to drive when pressing on a bit.
L
loramos
350sl
thanks guys mine is just a bog standard 350 with no abc.
L
loramos
350sl
I really do , only two confirmed cases of corona here out of a population of 18500. But it looks like thing might get back to normal after the 12th April. However most of the locals and their business'es won't be so lucky. Stay safe eveyone wherever you are.
Once again thanks everyone for your help .This really is a great forum.
ajlsl600
france
that in many ways is a plus at least as far as wallet goes.. must admit i now drive cars that wallow and roll vdoz did none of that !!
Count yourself lucky :p
ABC is a double edged sword.
On the one hand the grip and comfort is second to none, but on the other if it plays up it can take the shine off all that earlier enjoyment....
ajlsl600
france
no pain, no gain
gassed up
liverpool
2011 C207 350CDI;2010 C207 350CDI sport;2010 SLK300;2004 C209 320;2000 C208 230K;
Ain't that the truth:rolleyes:
