Hot air
mercmadjim
Cornwall
SLK230k
The heater in my SLK only sends out warm air, I can't get it to blow cold.
I have gone through the site, and I am guessing the problem is my duovalve, my car is non-aircon, can anybody confirm my suspicions?
Thanks.
mercmadjim
mercmadjim
Cornwall
SLK230k
Thanks Malcolm, so for ordering purposes it's called a duovalve?
Indeed it is called that, do you have a voltmeter where you could check the voltage going to it
mercmadjim
mercmadjim
Cornwall
SLK230k
Yes, I have got a multi meter, should I check there's power getting to it? is it on a fused circuit? my blower motor is a little rumbly, can that affect it?
Thanks.
Though it is a pulsed voltage going to it, some sense can be made with a volt meter, unplug the connector from the duo valve, and there are 4 wires I think, 2 for each side, just plug into 2 of them and change the heater settings and the voltage should change, max voltage when set to cool.
Though nothing to do with this, if the fan motor is noisy, it would pay you to drop it and lubricate the bearings
mercmadjim
mercmadjim
Cornwall
SLK230k
Thanks for that Malcolm, where is the fan motor please?
