How DO I Check How Much AdBlue I Have
mozabar
ML350, 2013 3L (2987 cc) Diesel
I have a 2013 ML350. I've been trying to work out how to check how much Adblue there is in the tank. No matter how much I look thoruhg the instrumentation I can work out how to check the Adblue level.
Does any body know how I can check how much Adblue there is in the tank?
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Even if you go into the service menu ,it'll probably only say 'full'
Or
Not full.
Best thing to do is fill it right up, then you know how much is in.
An icarsoft scanner should tell you the proper levels tbh.
M
mozabar
Yeah, there's no AdBlue option in the service menu.
What's an icarsoft scanner and do you have a link to one that you can share with me?
Hello and welcome,
I don’t think there was ever an option for level check on early AdBlue systems @EmilysDad might know.
There’s probably a warning when it gets low and that’s it.
onefortheroad
uk.
Hello and welcome,
My 16 reg e350 didn't show levels , just ,full or not full . It was in the service menu when you pressed phone and ok.
onefortheroad
uk.
Hello and welcome,
Guess yours was a W212 - my 2016 W213 showed quantity and range remaining
onefortheroad
uk.
Yeah last of the crop , registered march 2017.
ajlsl600
france
Or
Not full.
It will
ajlsl600
france
Adblue dictionary description..
A emissions based system that mostly does not work and costs a fortune to maintain. Followed or precided by multiple dash warnings
Don't leave home or go to Europe without AA or similar recovery. Delete adblue when possible or change car.
That's wot it shud say
EmilysDad
Bury Lancs
ML350
Hello and welcome,
Sorry for the lack of response ...... I was walking my little girl down the aisle yesterday. :)
Malcolm Johnson
East Yorkshire & Suffolk
R230 (M273) & W221 S350 bluetec
I would always break a piece of bamboo to a appropriate length and create a dip stick, then i got a nice man to alter this and other things on my ECU. Problem solved.
Altamar
South Wales
2015 SL400
I have a 2014 E220d and have the same problem. I was going to go down the "dip a piece of bamboo in the tank" route but haven't yet. I suppose the question is why do you want to know the level? I have a warning at 1000 miles and it counts down from there
The car recently did a 1500 mile round trip to France so I added five litres "just in case" and if if it helps, my car does about 16000 miles on a full adblue tank before it runs out
M
mozabar
Thats quite expensive way to find out the level of Adblue :). I'll just have to accept that there is no way to check the level.
M
mozabar
I think its just the principal really, you can check other fluid levels and I was assuming that something as integral as AdBlue would also allow me to check how much was in the system.
M
mozabar
Hope everything went well with the wedding
It was a new (hastily added) system at the time and it was thought that usage would be so low that it could just be topped up at each service.
With software updates usage has increased and newer models have displays in the dash menus that show fill level.
mioba
Nottingham and Köln
Treat it like washer fluid, every month odd when you pop the bonnet keep it topped up.
Bay Leaf
Stockport
SL 350 R231 2013
If Adblue has a shelf life is it advisable to fill the tank if your not doing a high mileage.
