How do I clean my EGR?
duncanh
Wiltshire
BMW 520d SE F10, formerly c220cdi estate (for 12.5 years and 345k miles), before that w124 and w210
Anybody got a "how to" for checking/cleaning the EGR on a 2002 c220 cdi?
There appears to be a lot of threads where the answer is "clean the EGR". I cannot find one that gives me enough confidence to tackle the job.
I believe that I may need to clean mine, power is down, fuel consumption has increased, and I emit clouds of black smoke at over 3000 rpm.
As I have recently had all of my injectors refurbished and a new MAF, it points to the EGR (unless one of my refurbished injectors has gone faulty). As I have now done over 220K miles, it is likely to be very dirty, maybe sticking.
As I have never had to deal with an EGR before, I would appreciate if someone could tell me how to find it, what it looks like, and what I need to remove to get at it. Any suggestions about what to use to clean it? How fragile is it?
Pictures would be great.
Xtractorfan
S class
The quick clean answer is to remove the EGR actuation valave and liberally spray as much freeing oil..TS10, WD40, 3in1 easing oil, or whichever oil you prefer..let it sit for 5 or 10 mins and liberally spray again.. then connect everything up and afer a few mins warm up, a few good revs and a quick run should clear the cobwebs.....
Naraic
2005 CL500.
Good answer...but the OP would like to know where the EGR actuation valve actually is.
jasonyw
Banned
c180/1997/1.8;W211/2005/E200K
It near the bulkhead. I got nabbed on my R170 petrol while working away from home in dusty M3. It cannot be cleaned but replaced, two of them. If you are not careful, it could snapped the tube and it even more expensive. Leave it to the expert. It costs me £260, done at MB Basingstoke.
Naraic
2005 CL500.
What the hell are you talking about...you are not just a Dragon... you are worse...a troll.
duncanh
duncanh
Wiltshire
Thank you for your reply. It not a lot sense make it do. (Even I can speak Dragonese!)
I note that you have now been banned from the "other" MB forum. They are convinced that you are indeed Dragon, who has been banned from both fori.
I think you may be on borrowed time.
Dosco
W211
Where on earth are you coming from:confused: I don't understand a word you are on about so gawd help the OP:shock:
Naraic
2005 CL500.
^ Indeed........
jasonyw
Banned
How do you clean the AGR?
The two components to change are the purge valve and vent valve and they are near the bulkhead. I was told by MB Basingstoke if you are not careful removing the purge valve, then the tubing underneath the purge valve may break even done by an expert causing even more work.
I was telling you a story, it happened to me in 2007 when I was working away from home around Camberley when they were putting barriers beside the M3 motorway filling the motorway with a lot of dust. It was at that time the engine light of my slk R170 came on. I was robbed(nabbed) by MB Basingstoke of £340(260, can't remember) to replace the two components. It very common but not mentioned in the maintenance schedule.
For curiosity there is a charcoal canister in W202 and R170, is there one in the W211?
Oarsman
Norfolk
W221 S350L CDI Bluetec, Range Rover Vogue SE 4.4 TDI, 1963 Triumph TR4
Miracles do happen. He can communicate in English.:lol:
jasonyw
Banned
Happy?
This is Anglo English, sorry can't converse in Saxon English, they are different from my experience a little bit long winding to be understood.
dieselman
A diesel
The O/p's car is a 220 Cdi...that's a diesel...;)
jasonyw, you are talking about the SAI system (secondary air injection) used on certain M111 compressor engines to help with cat heating and emission issues - nothing to do with egr as this system sends air into the exhaust, not the other way round.
jasonyw
Banned
You are in Stowmarket, aren't you?
How much will you do a change in auto fluid and filter for a W211?
ALFIEBEARD
DUMFRIES
JAGUAR XF-R SPORT
ROFLMAO:lol::lol::lol: I want whatever he is on:lol:.
Alfiebeard
ALFIEBEARD
DUMFRIES
JAGUAR XF-R SPORT
Glad you understood it all:confused: AGR!!!:rolleyes:
Alfiebeard
fluid, filter and gasket change including torque convertor flush is £140 inc vat and labour for the 722.6 box. for the 722.9 box it is P.O.A
jasonyw
Banned
2005 W211. Is mine 722.6 or 722.9?
S.Speed
Lancashire
Older Citroen Now :-(
Is yours 5 speed (722.6) or 7 speed (722.9) ?
Thats the difference.
jasonyw
Banned
5 speed, I know the answer now, thanks.
Is the £140 include the fluid, filter and gasket?
