How do I know if I have a DPF?
Scottie CLK
St Helens / Snowdonia
CLK/2005/220CDi
Hi, I have a December 2005 CLK CDi 220.
Had it for two months and am very impressed. It went in for a remap a few days ago, and before it had a health check and RR run.
There is a power dip around 2300 to 2700 rpm and it shows the error code 2632 "chech charging system : charge too high".
A little research suggests first course of action is to clean out the EGR valve, then process to check cat and DPF.
I would therefore be veyr grateful if anyone could answer the following :-
1. Although the EGR can be cleaned, is it better to just blank it off?
2. Does the car have a DPF, or is it just a standard cat?
3. I'm told as it's a diesel the car can pass MOT without Cat, so if this is blocked or causing problems can you just use a decat pipe?
Car runs great apart from this power dip and makes the power and torque it should elsewhere.
Any other suggestions welcome as I need it to tow my track car :)
Many thanks,
Scott.
brandwooddixon
Wolverhampton
S63 Coupe 2014
A 2005 car is unlikely to have a dpf. If you're unsure then search on here for a VIN checker link.
Was the fault code read by STAR or a generic reader - some codes are year and model specific?
A
andy@pcd-ltd
Has the fault only started to happen since the remap has been carried out
Scottie CLK
CLK/2005/220CDi
Hi, thanks.
The fault was present before the remap, it was brought up in the health check and RR graphs showed it, it occurs between 2300 and 2700 when you accelerate fully, it won't show under partial acceleration and runs full boost spot on above 2700 and belwo 2300.
It is a little worse after the remao as the car runs a little extra boost now so hits the limit and the ECU cuts the boost which causes the dip spike in the graph.
First reader was a small hand held one, not sure if the second reader he borrowed was a STAR, it logged real time faults, let you clear codes, was about laptop size.
_Taz_
Kent
2011 E63 6.3NA AMG Tenorite Estate MCT 7g
^^ As andy, charge too high means ( I think ) that the ECU is seeing too high boost & backs off the ECU.
As for the DPF, my old bus is an "E" on a 320cdi, yup, it has a damned DPF :Oops:
clean tailpipe = DPF
Sooty = nope :D
it may be the mapper has not altered the overboost setting in the ECU, I'm not familiar with the ECU setup, some just use a crude pressure switch / sensor that just gets recalibrated.
Scottie CLK
CLK/2005/220CDi
hi yes the issue is the ecu is seeing overboost just at abut 2500 revs and backs it off, but then boost is ok before and after that point.
I'm ruling out injectors, actuator, turbo as otherwise the problem would be at all revs.
Reading round so far seems to suggest a clogged EGR valve or restricted cat can cause this particular symptom, and possibly a DPF if the car has one.
Alex Crow
Super Suffolk
...Reading round so far seems to suggest a clogged EGR valve or restricted cat can cause this particular symptom, and possibly a DPF if the car has one.
Actually, those will cause lower boost pressures, not higher.
If you have the original service book with data card, DPF is code 474 - no code = no DPF.
Also, you will have a sensor mounted immediately to the rear of the air filter housing on this car if DPF is fitted (and should have oil sticker for low ash oil too).
Scottie CLK
CLK/2005/220CDi
Thanks, will take a look. I would have thought blocked cat would cause higher boost pressure as it created greater pressure on the output side and thus slowed air down out of the exhaust side and made it easier for pressure to build on the inlet side.
Obviously I appreciate your knowledge on this as I only really have experience of rotaries and four pot Jap turbo engines! :)
What would cause boost dip at 2500. RR graph show straight line for torque from about 1500 to 4000 rpm, with a sudden dip from 2300 down to 2500 back at top at 2700, torque goes from 230 lb/ft to 180 at trough of dip.
Scottie CLK
CLK/2005/220CDi
Is there a guide to how to remove the EGR for cleaning or is it just the two obvious bolts?
THanks.
Scottie CLK
CLK/2005/220CDi
THanks will give it a try, didn't want to come off so wasn't sure if it was more complicated or just needed a bit of force :)
Scottie CLK
CLK/2005/220CDi
The EGR was cleaned yesterday, was apparently filthy and not even operatign properly.
The good news is the problem is 80% gone now, but am trying ot work out he last 20% :)
The VIN is WDB2093082F184104
Can anybody tell me what that means? I assume the lack of 474 means no DPF?
Thanks,
Scott.
Alex Crow
Super Suffolk
Did this ^^ not help?
Data card in back of service book BTW, and the chassis number does not contain a DPF specific code.
Scottie CLK
CLK/2005/220CDi
HI unfortunately I do not have a service or any book with the car, I jsut got an electronic service print out from Mercedes Stoke / Lex and an MOT history i checked myself from the government website.
Scottie CLK
CLK/2005/220CDi
I can't see any "low ash oil" sticker and there was no obvious sensor immediately after the ari filter housing before the AFM.
Alex Crow
Super Suffolk
Nope, sensor at REAR of air filter housing, not front.
mersum1es
Finland
Russians give:
vin WDB2093082F184104
whc WDB
chassbm 209308
chass_ident 2F184104
type 209
subbm1 308
subbm2
auxiliary_drive
body
body_code
delivery_date 051101
engine 646966 30 481566
front_axle1
front_axle2 AL254050936676
heater
interior 711A
lights
model_idx 0
odometer
order_num1 0553735650
paint1 040U
paint2
paint3
paint4
paint5
platform
production_num1 2172353
production_order_ref N
rear_axle1
rear_axle2
release_date 051101
retarder 8 051101
rims
service_num
steering
trailer
transfer_case
transmission 716654 02 178384
vin_dc
vinwhc
winch
wiper
Code Текст
M22 DISPLACEMENT 2.2 LITER
NM5 Unknown
R52 Unknown
U18 AUTOMATIC CHILD SEAT RECOGNITATION (AKSE)
249 AUTOMATICALLY DIPPING INSIDE REAR VIEW MIRROR
411 Unknown
461 INSTRUMENT WITH MILES IND. AND ENGLISH LEGEND
477 Unknown
500 OUTSIDE REAR VIEW MIRROR LH AND RH FOLDING
523 RADIO AUDIO 20
551 ANTI-THEFT/ANTI-BREAK-IN WARNING SYSTEM
573 Unknown
580 AIR CONDITIONING
600 HEADLAMPS - CLEANING EQUIPMENT
613 LAMP UNIT - ASSYMETRICAL, LH TRAFFIC
666 10-HOLE LIGHT ALLOY WHEELS WITH WIDE TIRES
690 Unknown
710A Unknown
739 Unknown
806 AEJ 06/1/M/X
875 HEATED SCREEN WASH SYSTEM
882 INTERIOR SAFEGUARD/TOWING PROTECTION
926 AIR POLLUTION CONTROL D4 EU4-MEASURES
954 EQUIPMENT PACKAGE FOR AVANTGARDE VEHICLES
983 VEH. TITLE OF OWNERSHIP-OMITTED AND W/O COC PAPERS
989 Unknown
205B OWNERS MANUAL AND SERVICE RECORD - ENGLISH
221B INFO PLATE, COOLANT - ENGLISH
250B Unknown
283B Unknown
5XXL EUROPE
040U BLACK
711A Unknown
Scottie CLK
CLK/2005/220CDi
  • #18
Thanks for that, had a look today, the back of the airbox opposite to the bulkhead is just flat and can't see a sensor anywhere.
Car runs much better after EGR clean so just weighing up whether to remove it all together.
Will probably get the cat knocked out at next service as well, can only help I'd imagine. This is the first diesel I've had but all previous petrols I have always decated.
rf065
Grossbritannien
Not sure if the CLK was ever fitted with a DPF a standard. Certainly in 2005 and as late as 2007 it was an option only, I doubt they would fit one as standard after that as it would then be an outgoing model due for replacement.
Russ
David-Butter
Suffolk - East Anglia
www.sntuning.com
mercedes CLS 320CDI , landrover discovery 3.0 twin turbo and Ferrari F430 Scud
Id have the DPF out, No end of issues with them forced regenerations from the dealer cost over 85+VAT i payed just over £300 to have it out and save a lifetime of issues.
