How do we clean steering wheels, gear knobs etc ?
Omega
Cornwall
Hi guys,
Whats the best thing to clean steering wheels, gear knobs etc ?
I know it might seem a daft question, but I’m not 100% certain what they are covered with, and don’t want to over do it.
They started to get a bit sticky about 6 months ago,,,, but after someone left a window ajar in the rain yesterday, they got worse.
Is soapy water o.k ?
Is alcohol needed ?
Soap and warm water is what I've used in the past . Cheap ,quick and easy . Try that first
Craiglxviii
Cambs UK
Soapy water works well. Fairy liquid and a nail brush or old toothbrush will also work. I use Gliptone cleaner and conditioner, which I'd fully recommend. It makes the car smell of rich new leather once it's been done, for about a week :D
+1 for gliptone leather cleaner. It's great.
A.J.
Norwich. UK
Flash all purpose wipes, baby wipes. Surprising the amount of dirt and whatever they lift off no matter how regularly you do it. :)
Small amount of Ariel liquid diluted in bowl one
Micro fibre cloth damped in said liquid, use circular motions to clean off what will be revolting....
Bowl 2 with clean water and clean microfibre cloth damped to rinse off
Apply Gliptone as Craig and Alex suggest....
Mine differs slightly in that I have Alcantara grips
So no Gliptone but after the 2 bowls I use a hairdryer to dry the Alcantara whilst rejuvenating it with a Nubuck suede brush......
Obsessive, moi?:rolleyes:
ZZZZ
As above, and I also use covers for the steering wheel and gearshift handle, whenever the car goes in a garage, or when I'm working on one of my silly mods ... Oh, and unscented baby wipes, in between proper cleaning / Gliptone treatment.
CJD
Bourne
C200 AMG Line, Premium Plus, S205 Estate, 2018
For cleaning normal leather covered steering wheels - especially ones that have gone shiny , I use a magic eraser sponge and a little bit of water.
The results can be very impressive - just take it gently and don't rub very hard.
Craiglxviii
Cambs UK
You use a two-bowl method for your steering wheel?!
What flow rate do you fill the bowl with? :D I have a 900 litre per second outside tap and I fill the bowl for 5 minutes straight to remove any contaminants. Is this sufficient? ;)
JBell
Torquey
C350 CDi Estate (GAD Edition)
John has professional Bowls that are bigger than everyone elses
JBell
Torquey
I use baby wipes and Gliptone
2 bowls, 3 microfibre cloths,one hairdryer and one nubuck brush, I beg your pudding!
You’ll have to be in the region of 4 litres per minute Craig depending on the bowl size, however I would run the tap for several weeks before use and then ( and only then) run the water through a filter and additionally boil it until steaming, and allow to condensate back into the bowl
Also only use a clear or opaque bowl so you can see the contaminants and also the condensation process
Sure I’ve forgotten something here... :rolleyes:
keefysher
Hampshire
W166 GLE350AMG Line 3.0 2017. BMW Z3 2.8 1998.
Prevention is better than cure. If you pick your nose don't wipe your fingers on the wheel, swallow the bogey ;):D:D
Frontstep
T210 320cdi
One should use driving gloves to save contamination, they are available at all good charity shops.
www.ckinsurance.co.uk
