how much to take c class out of safe mode?
rob_k
hi guys been having trouble with my auto box. got it fixed now but need it taking out of safe mode.
what do they charge for this at merc? Thanks
dragon
Banned
For a start draining the fluid and fit a new filter will cost you £150, I remember Malcolm said.
It may be cheaper if you DIY, 5/6 litres of fluid and a filter and slimmy hands.
The safe mode may not be the auto box problem, it could be the MAF, £145 from Bosch and more from MB dealer.
Safer to get it diagnosed to find the right cause of the safe mode.
R
rob_k
ive had it diagnosed the problems all sorted just need it taking out of safe mode?
A bit lost here as the car gets locked into the safe mode because of a fault with speed sensor signal or conductor plate normally, and if the fault is fixed, then it should be out of the safe mode
kth286
E320 Coupe 95
dragon
you make a "million" posts a day, do you not bother to read the original poster's notes that you are are responding to ?
Perhaps less haste will achieve more speed for you.
It is only annoying because we have to read through your superfluous answer to then realise it was totally irrelevant to the original posters' question.
dragon
Banned
dragon
How do you know the auto box causes safe mode?
My recommendation to have it diagnosed and clear all the fault codes is still valid.:rolleyes:
What did you suggest?:mad:
BlackC55
South coast
C43
He has tried to clear the codes bujt the tester he is using won't.
he is poping in to see me today at 2pm.
Then he will go home a happy bunny:D
dragon
Banned
Funny, the fault codes can only be cleared with MB STAR.
I had fault codes created several years before I bought the car. I tried Carsoft 7.4 and EOBD II scanner and I thought I cleared it and when I used MB STAR are still there.
It a good way to find the history of the car if you bought it second hand whether it had been abused.
Xtractorfan
S class
My experience has been Engine limp mode will cure itself once the fault has been fixed, gearbox limp mode has to be cleared on the star machine..
