How to change and what bulbs to use on 07 w211 fog lights
mercmancdi
templepatrick - co antrim
www.schnauzersinireland.com
my fogs are yellow on 07 w211
I think it’s mostly the bulbs , I have
cleaned the lens but the inside is a bit discoloured, but a change of bulbs might do , what bulb is best to get for figs and are they easy changed.
Sorry I have searched but can’t find previous post.
AnthonyUK
Alton, Hants
C240 estate 2002
I'm not sure if they are all the same but H11 are pretty common. I fitted Nightbreakers but LEDs might have overtaken them by now.
There mayvbe a small panel on your arch liners you can remove for access but if you have a headlight wash system, the reservoir might make access a little difficult.
mercmancdi
mercmancdi
Thanks ,I have headlight wash.
Have not had proper look yet .
If I though the lamp could be changed easy I would do that as mine are discoloured a bit inside.
But would not want a big job like removing bumper etc.
ZZZZ
  • W211 Remove_install fog lamps.pdf
mercmancdi
mercmancdi
