How to change / charge a CLK battery
Derek Mck
Edinburgh
CLK 200 2001
Hi folks, I hope someone can help.
My CLK battery is flat. I am about to splash out on a charger but a thought has occurred to me.
The battery is in the boot, so if I remove the battery and close the boot, how will I get back into the boot to replace the now charged battery?
I live in a flat and the car is parked on the street, so I can't leave the boot open while the battery is out of the car being charged.
Am I being daft here? I'm just worried the the boot wont open without electric power, which the car won't have because I will have the battery.
Any thoughts appreciated.
Thanks,
Derek
Naraic
2005 CL500.
Do you have the metal key? Also...without the battery, how will you lock the car?
As above do check that you can access the boot via the metal key
whitenemesis
CLS55 AMG '05
First question to answer is why is the battery flat?
If everything is ok with the car e.g. no untoward drains on the battery, could it be it has reached the end of it's serviceable life, in which case buying a new battery would be much simpler.
D
Derek Mck
Edinburgh
CLK 200 2001
Ah. I think you have answered my question. I have the metal key, so I can open boot and lock door?
I knew I was being thick!
Thanks - Derek
Thanks - Derek
Do try it first in the boot lock to make sure that it will open
Pathfinder
Gourock
I wouldn't buy a charger, I would buy a new battery.
Tel: 020 8863 9233
