Parrot of Doom
- Nov 14, 2005
- Location
- Manchester
- Was an E300TD, now a Lexus LS400
note: The original thread including all replies to this is located here > http://forums.mercedesclub.org.uk/showthread.php?t=18298
Feel free to point out any glaring mistakes I made while doing this
My engine has been playing up a bit, surging when cold in the morning, occasional misfire. Chief suspect (and cheapest to investigate) was the MAF, cleaning it would certainly do no harm. So heres what I did:
First, open the bonnet (duh!). The MAF can be found exiting the air filter box for the engine. On mine (300TD) its on the offside of the engine bay, at the front. You can see a small electrical plug attached to the air intake.
1) Remove the plug
2) Unclip the air filter box
3) Undo the MAF from the hose by unscrewing the Jubilee clip.
4) Remove the MAF from the air filter box, using a philips screwdriver (2 screws, 1 is hidden slightly) Once the screws are undone, you have to tug quite forcibly to pull the MAF away from the filter box. There is a large O-ring between the two, once separated check the O-ring to see if its in good condition. If its a bit knackered, get a replacement.
1) Remove the plug
