How to control the illumination on the radio/tel/nav during driving in the night?
robert_winter_1000
The Hague, The Netherlands
MB E350 CDI (W212)
Hello all,
To dim the lamps on the dashboard of the MB is quite simple, turn the button on the dashboard and that is it. I have a problem which is the illumination of the radio/tel/nav is too bright for me when driving in the night. Is there a way to reduce this brightness?
Kind regards,
Robert
onefortheroad
uk.
Which car .
Srdl
Hampshire
GLC43 AMG 2018 (X253)
Hello all,
Kind regards,
Robert
There should be a brightness setting somewhere probably under “System Settings” or “Vehicle” depending on your particular era Comand/Audio 20
AMGeed
Poole, Dorset
S204 C180K
Have you set the Sat nav to automatically turn the (night setting) screen dark at night?
It's done in the setting in Comand.
Botus
S500/2010/500
good point...
Chrishazle
Nr Ashford, Kent
Also goes dark if you drive into a part of a road with overhanging trees cutting out the light - then goes back automatically to normal when you come out of the darkness!
Bay Leaf
Stockport
SL 350 R231 2013
On my 2013 SL the panel above the climate control panel that has all the buttons for the radio / sat nav etc doesn't light up when the lights are on is this normal.
Craiglxviii
Cambs UK
Depends how dark it is outside
Bay Leaf
Stockport
SL 350 R231 2013
I've found out that if the system is not switched on it doesn't aluminate, that might seem obvious but everything else in the car does. The on/off button however is illuminated so obviously it can be seen in the dark. So the problem I thought I had, doesn't exist. Is there a setting I can use so it can be illuminated all the time. 20201004_152336.jpg
