How to do a water pump - 1 Hour on W202 C180
gogsey3
stornoway, Isle of Lewis
mercedes c220 cdi avantgarde, ford fiesta
:DCheers Malcolm that would be excellent and really helpful cos at the moment I'm in the wife old fiesta and its awful:(. So hopefully I can get it done tomorrow:D
I will do this after I have eaten :D:D
You should have the details in you mail box :D:D
dancingducks
New Registration
Burton
Elegance C200 1994
Water pump change
Just to say glad I read this first. It made the whole job straightforward and much easier than I thought. Thanks
max2004
British Columbia
1997 c230 / 1990 190e
Water pump metal particles
1997 C230 4 cyl 94000 KM's
Pulled my water pump off this AM, found metal particles under the pulley.
Belt is badly burned and melted onto the pulleys.
Pump bearing is VERY worn out, looks like it scraped the front of the block.
Very smooth scrapes and I saw no particles.
Got it all cleaned up and will bolt on new pump tommoro.
Should I be worried about metal particled ionside the block?
Is there a special way to flush the block/rad?
Thanks,
dbanbery
dbanbery
Huddersfield
1995 R129 SL500
  • #28
Thanks,
Not really, as most of it will collect in the bottom of the radiator. tbh if you have metal bits in the coolant system i'd undo the drain plug on the rad and drain it out then flush it with a hosepipe in the expansion tank to get all the detritus out. ive just done this job on my C250TD and it took longer due to a viscous coupling bolt rounding, and due to the bigger engine. that had metal bits and i just flushed the coolant system. this would make the job take longer though!
max2004
British Columbia
thanks dbanbery,
Pump went in without a hitch.
Put in a new belt also, got it for less at the stealer.
Thats a first!!
dbanbery
dbanbery
Huddersfield
1995 R129 SL500
  • #30
thanks dbanbery,
Thats a first!!
yeah the belts are cheaper than the dayco ones at GSF or similar.
there are also other random bits too that work out cheaper but its pot luck mostly.
geordiec
motherwell scotland
C200estate 1998
replaced the waterpump on my 1998 c200 everything was fine but now heater is not very warm any advice
dbanbery
dbanbery
Huddersfield
1995 R129 SL500
  • #32
check there is not an air lock by running the car up to temperature with the rad cap off and the heater on full blow, also give the big pipes a good squeeze periodically while the car is heating up. if there is still a problem then it might be the heater valve. the only time ive had problems with the heater not working properly has been to do with airlocks.
geordiec
motherwell scotland
C200estate 1998
have already tried what you have said everything was fine after fitting pump but now only getting a bit of heat when blower is running slow speed turn it to hi speed and it goes cold have ordered a themostat to see if that helps
dbanbery
dbanbery
Huddersfield
1995 R129 SL500
  • #34
if it takes ages to get warm then the thermostat is goosed. if not, then i would say it is the heater control valve.
Tju
Essex
S211 OM642, A209 320, W220 OM648
Would anyone know by any chance, if changing the Water Pump on a 2002 S210 E220 Cdi, is similar to the petrol engined model in this thread, as Ive just bought said car with Leaky Pump and managed to drive it home yesterday 148 very tense miles, so I feel that seeing as it got me home without any need to call the breakdown People, it deserves a New Water Pump ASAP.
Anyone's help or advice would be appreciated,
Thanks,
Terry.
dbanbery
dbanbery
Huddersfield
1995 R129 SL500
  • #36
Thanks,
Terry.
the diesel is comparable, but it wont be as easy as this because of the space issues. it will be in a similar place though, so i would recomment doing it. you will probably need to remove some plastic panels and you may need some torx bits but otherwise i don't see it being too difficult.
Tju
Essex
Thanks for the advice. Guess what I'll be doing tomorrow then;)
