How to lest fuel pressure
Karl W
Wakefield
Merc (W124) Estate , Mk2 Golf GTI (Under Rebuild)
I don't have a fuel pressure testing guage and neither does the local garage, Is it possible to read the fuel pressure through the 16 pin diagnostic port. I can fault code read the system using a power scope.
My local garage has various old testing equipment and they are sure they'll have something that works but they and me don't know what pins to connect to on the diagonstic port to find what the fuel pressure is at the injectors.
The car is a 95 e200 W124, thanks for reading.
No, the only way is with a gauge connected to the pressure test port on the fuel rail.
If I may ask, why check it?
K
Karl W
Wakefield
The mixture is running lean when warm, so I want to check the fuel pressure at the rail before working back to the pumps. When you spray some engine start spray in the air intake it sorts the problem.
What are lambda values doing?
Any fault codes to go with?
K
Karl W
Wakefield
It's always been error free, I just get the blink from the light that denotes no error codes. I've just replaced the Lambda sensor the previous sensor was warnout and was the orginal item so changed it for another OE sensor from the dealer. Tickover it fine warmed up give it some gas and it's going lean. It would be handy if I could see what was happening on the road you don't have to go far before it's popping n banging
mattkh
England
A160 W168 1999 1.6
Hi
Another way would be to replace the fuel filter and see if it runs better.
How old is the fuel in the tank ?
How can you be sure it is lean, what is the lambda voltage doing?
K
Karl W
Wakefield
Hi, I ran the volt meter over the sensors and voltage and ristance os fine. When I fire it up it will start fine from cold and after giving it some revs it starts to pop annd bang. If I spray some fuel into the air intake and rev it no problems. Thanks what making me think it's running lean
