How to Remove Heater Control Unit?
northcave
300sl/1992/3l
My control unit has died and I need to get it out. Could some advise on this please. It is a 300sl 129. (12v)
Part number is: A1298300185
N
northcave
300sl/1992/3l
  • #2
Just thought I'd bump this one back up and see if i can get a result :)
Yes you have a result :D:D
Remove the radio and press the tab each side just under where the radio hole at the top,,and it slides out
MB-Car-Tech
Reading
C 230K - SOLD now running E320T CDI
Northcave,
from memory you have to remove the radio and cage if fitted.
there are two lugs that have to be prised down (gently) whilst pushing behind the heater control unit.
you will see these two lugs in the upper opening when the radio has been removed.:D
