How to remove lower ball joint from controlarm on a 2014 w205?
Janibanani
c180/2014/Petrol
The joint is normally pushed out from behind with a tool but that wont work on this controlarm
any ideas on how to get it of? Can i pull it off with a cup by the threads on the joint?
Do you want to re use the joint, or are you replacing the arm?
Janibanani
c180/2014/Petrol
I was planning to only change the ball joint on the end of the arm. They are sold separate.
They will be pressed in if they are removable. You'll probably need a hefty press to shift it
Generally easier and quicker to change the complete arm.
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Any photos of said arm ?
Janibanani
c180/2014/Petrol
Look at the link in the original post. There you can see both the arm and the ball joint. What im asking for is how to extract the ball joint from the arm.
Uncle Benz
West Sussex
Mainly Mercedes
What link?
And I told you, however my parts diagrams don't show separate ball joints.
mioba
Nottingham and Köln
You will needs to source the rubbers separately.
You will need an Indy with a press to get the new rubber on.
The arms rarely fail it’s the rubber.
Janibanani
c180/2014/Petrol
Im sorry, i provided a link from Google with all the parts involved but it seems the moderator removed it. I will upload imagets ASAP
Janibanani
c180/2014/Petrol
Uncle Benz
West Sussex
Mainly Mercedes
As LostKiwi, it’s part of the arm, and not replaceable on its own. Where have you found a replacement part?
onefortheroad
uk.
I'd imagine the machine that presses those ball joints in does alot more than just push the ball into the socket . The forces needed will be really high tonnages . If it was meant to be changed ,it would of been a bolt on type. That's not happening I'm afraid . New arm time .
onefortheroad
uk.
Uncle Benz
West Sussex
Mainly Mercedes
That balljoint is the one halfway down the arm that the anti-roll bar mounts to, not the one you marked in red on your other link
Janibanani
c180/2014/Petrol
  • #20
Ok. Thank you all for clearing this out for me. New arm it is then. Case solved
