Howto: Duovalve maintainance
Interesting to see that one of my solenoids had a drop of water in it. I cleaned that out.
CPC supply various section rubber belts in various sizes. If a seal kit is not avaiable for the duovalve, then this may be a way or refurbing a leaking unit?
Anyone know roughly how much a new duovalve is from the dealer?
There is a very good post on Benzworld in the 140 section with all details of the rebuild of the solenoids.
jonclancy
The V12 Uberalles link is dead now.
But I found what looks like the text only reproduced here:
http://blog.daum.net/gogosmotors/47
O-rings in the referred size are on eBay. £3.75 per 10-pack
CODE : OR BS016 N70 (10) BS016-N70 (Pack of 10)
O Ring Round Section Seal - Suitable for Flanges, Recipricating or Rotary motion.
Size : I/D 15.6mm x 1.78mm Cross section (5/8x3/4x1/16")
Material - BLACK Nitrile Rubber 70° Shore Hardness - Working Temperature Approx -40°C to + 110°C
AmacoFL
New Registration
Coral Springs, FL USA
1996/E320/3.2
TO: PARROT OF DOOM
Great job of explaining the process. Excellent pictures.
I live in Florida and my wife drives my 96 E320. Got in the car yesterday when it was over 90 degrees F. Started it and got blasted with heat from the drivers side vent and the drivers side of the the center vent. Passenger side was working normally.
Went online looking for answers and I was seeing all sorts of codes being discussed and a bunch of people saying that the system needed to be charged.
I wish the wizards who are guessing (i.e. needs a charge) would not offer their suggestions.
If it is blowing cold, you obviously do not need a charge!
I was thrilled when I found your write up because it made total sense.
I just came from my garage. After reading your terrific, informative article, I did the most obvious repair.
I located the valve, hit it about 20 times with the handle end of a heavy screwdriver and then started the car.
While the car was running, I kept hitting the valve in order to free it up.
Checked inside the car when it reached full operating temp and was happy to see that it no longer was blowing hot.
I realized that it was not blowing as cold as the passenger side, so I can logically assume that the valve freed up most of the way, but is still letting in a little hot coolant.
At this point, I plan on smacking this thing daily when the car is being used and if it doesn't return to normal in a few days, then I will follow your terrific explanation.
Thanks again.
Cool Joe in Hot Florida
rodisi
Germany
E220CDI 1999 W210
Thanks PoD for the effort you've put in to explaining this duovalve business. However, you cheated, you chose a car that was nice and easy to get to the connector of the valve. :) On my E220 W210, the buggers went and put it right next to the a/c unit and almost impossible to put fingers in to get to it.
Anyway, I noticed a couple of nights ago that one of the rotary controllers was not lit so I thought I'd have to change the bulbs. Last night, it was on but then I noticed that I could not regulate the heat, it was on all the time. I tried the a/c but that doesn't appear to be cooling so I searched and came across this very helpful thread, which I shall follow, however, I have a couple of questions before I do.
Malcolm said
for where to find the pump. This link doesn't exist, is there an update?
Also is there anything that can be checked in the rotary switches? I mean can one get to the back of them to check?
Off topic, in the attached photo, to the left of the duovalve, there appears to be a tube with an open filter at the end of it. What is it?
Basically do you have any voltage on the center pin in the connector, it should be at 12volts. it needs 12 volts to put the valve in the cold mode, this variable voltage comes from the controller and it swings from 0 to 12volt on each outer pin dependent on the controller settings.
The pump is 83 and this feeds to the inlet of the duo valve, this is not responsible for no cool air.
index.php
The fuses involved here you can see in the top here
http://www.autolib.diakom.ru/CAR/Mercedes-Benz/1997/E320/SYSTEM WIRING DIAGRAMS/6215.pdf
rodisi
Germany
E220CDI 1999 W210
Thanks for that info Malcolm, I shall update when I manage to find a way to take the connector off.
A thin meter probe will go in the top of the plug, no good in taking it off to measure as it will be in a no load condition. Use a needle with the meter probe on the needle.
Alex Crow
Super Suffolk
The air filter is for ingress of air to the vacuum system for the Turbocharger vanes.
The duovalves on the W211 cars can be lifted away from their lower section, making replacement a lot easier.
In the picture above, you can see the ends of the metal clips that hold the upper and lower section together - lever the clips outwards, and the sections should seperate.
IIRC anyway.
The duovalves on the W210 cars can be lifted away from their lower section, making replacement a lot easier.
IIRC anyway.
210 Alex;):D
rodisi
Germany
E220CDI 1999 W210
Excellent
I'm surprised - I don't have a turbocharger.
IIRC anyway.
My W210 may be different from others, Malcolm. I noticed the clips earlier and was wondering if that could be their purpose. I've arrowed the one on the left.
Alex, excuse my ignorance - do you mean that the lower section is fixed on the car and the upper section is what I need to take out to work on, if necessary?
rodisi
Germany
E220CDI 1999 W210
I just want to confirm that I'm measuring what I think I'm measuring (as an old lecturer used to say).
In the drawing below, supposedly of the duovalve connector, pin 1 has 12V and supplies an amount to pins 2 and 3 dependent on the heat control setting in the car. Where my connector is located, it is extremely difficult to access pins 1 and 2 so I'm checking the voltage between pin3 and ground. This may not give me the voltage supplied to the solenoid but it should give me a variable voltage according to the control setting (if my thinking is correct.
Now between pin 3 and ground(chassis) I'm getting 11.8V no matter where the setting is. Am I correct in assuming that there's something wrong with the rotating control?
Alex Crow
Super Suffolk
That is odd, a UK Mercedes CDI of any age will have a turbo on it.
In any case, the little filter is for ingress of air to the vacuum system, and is of little consequence, and certainly not involved with the duovalve.
The two halves of the duovalve can be split in the car, saving having to undo two or more awkward lower pipes, and having to remove the lower part of the valve from its mountings.
The upper part of the valve has the moving parts and solenoids.
You can clearly see it in Malcolm's picture, post #85
shaggy
be careful when doing it this way without first removing the pipes
I tried and snapped both the plungers :rolleyes: if they are weak to begin with they snap for fun!
I then got replacements and snapped 1 of them trying to get it back on
Alex Crow
Super Suffolk
rodisi
Germany
E220CDI 1999 W210
Mine is a LHD German model if that makes any difference.
So I take it you mean by unscrewing the 5 screws and not using the pins we discussed further up.
There is a huge amount of information on this subject out there on the web, some good, some bad.
Here are a few examples...
I looked at those and have been confused even further. Some questions have arisen from those links
1) how much coolant should I expect to pour out when I remove the hoses and open the valve?
2) somebody commented on the fact that the coolant was green and not honey yellow - do Mercs take a special coolant?
3) error codes where mentioned. I have noticed in the fuse box there is a big round multi-pin socket. Is that what's used for diagnostics and if so what do people use?
I'm also worried about the voltage readings I mentioned. I don't want to fool with the valve if it's the controller.
Again, thanks for all the help everybody.
This shows that the control unit is not adjusting the voltage, as I said to you, there needs to be zero volts on pins 1 and 3 to get cold air.
Why take the valve apart when the fault is not there or on it ?????
rodisi
Germany
E220CDI 1999 W210
Absolutely. So now I have to go to the control unit wherever that lives. I'll do a search on control unit opening and diagnosing. Thanks.
The wires that go to pins 1 and 3 come directly from the control unit in the car,the part where you adjust all the heating from.
Alex Crow
Super Suffolk
I am sure you will find that all the LHD Mercedes W210 CDI cars have turbos as well - I am suggesting you are wrong, but hey, not important or related to the duovalve.
How keen are you at automotive DIY?
It seems from your questions that your are quite unfamiliar, but still keen to get involved. There are all the answers out there, but no-one can put it all on a plate for you, to understand your way (we all understand in different ways).
You have had some very good advice here, and I suggest you continue with the electrical diagnosis side of things, as detailed above.
If it turns out that the valve does need to be stripped, I myself would go for removing the upper half of the valve from the car, and stripping it (as per many many internet threads) on the bench.
If you clamp the coolant hoses of, each side, very little coolant will escape.
If you don't, a certain amount will be lost - but no-one can tell you how much.
Mercedes cars are fine with standard coolants, nothing too special, but again it is all written on this forum and the web.
If the valve has gone closed circuit or low resistance, the control unit will refuse to switch the earths - what did the resistance of the two solenoids measure?
