Hydraulic Pipes for W124 230TE ~ 1990
tbone
I have a leaking pipe on the system , can any one please confirm the dimensions of the piping
used for the ~ front to rear ~ pump to self levelling valve ~ runs and tell me where I can buy some
and the necessary unions .
Also does this pipework contain the flow restrictor 'wire' or is that only used in the pipes
running to the rear 'shocks' ??
Thanks in hope of a +ive answer .
Tbone
supercharger
mansfield,notts
hi tbone i think this is just standard brake pipe some one will confirm this soon enough im sure you could just cut out the damaged piece and connect a new piece in.
supercharger
T
tbone
Thanks SuperC ,
I have been told by the mech at the MOT station
that he thought it was 6mm and non standard alloy .
We did 'hold up' some standard brake pipe against it
and it did look a fair bit thicker than that .
