Idiot's guide to Auto boxes in an E300 TD
pcman_jh
Haddington
2013 E220 Cabriolet
I'm thinking about swapping my A class for a E300 TD with an auto box, but I like to know what I'm taking on as I've never had an autobox car before.
As a fairly competent DIYer, what's the service requirements of an autobox - is there a clutch plate that can wear like a manual box; Does the autobox transmission oil need regular changing etc; are Mercedes autoboxes bullet proof like their pre-CDI engines etc...
Thanks in anticipation.
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
Auto boxes
Just change the fluid & filter regularly. Probably more often than Mercedes recommend. There's nothing else DIY-able in them in my opinion
No auto box is bullet proof. Reckon on a rebuild before 200k
Nick Froome
www.w124.co.uk
malcolm E53 AMG
Covered 120,000 miles in a 124 series auto and stuck to the recommended service intervals of 36K for trans fluid changes. Box was as good when I parted with the car as when bought.
The E320CDi I am running now has an autobox supposedly sealed for life but I will change the fluid anf filter at 50K. There is no dipstick on this model so a slight fluid loss can be a problem if un-noticed and result in box failure or erratic changes. I would imagine the 300TD uses the same 5 speed box but without the tiptronic (which I never use anyway).
Hope this helps!
tom7035
Auto-box.
Mine gave up after 130k, but had no available history. I was probably just unlucky. Apparently nothing to do with wear of the clutches or brakebands though, it had been performing impeccably up to that moment, something just broke.
Chazchuzzlewitt
Dorchester
W/S124 320TE Estate
the 'box in my old 300E was still going strong when I sold it at 200K+ miles. It hadn't been rebuilt and I had no probs with it, apart from fairly hard shifts.
