chastrain
- Jul 11, 2009
Hi, i have what seems to be a water leak around the injector housing/head, have shown this in the enclosed pic/attachment with a yellow arrow pointing to the problem area, with the engine running.. from what i can make out it seems to be bubbling water. Not sure whether this is coming from injector housing or perhaps and from what i've read could be a perforated head ?.
The green arrow points to fuel leaking on/around the injector and isn't coming from the fuel return pipe.
Many thanks for your help![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Ps, a previous problem with gearbox jerk was solved with a transmission fluid top-up, was above min, which 'i thought' was an ok level, so took it to max. Thanks to those that helped
