Injector problems
Nashley11
C class 2009 2.1l
Hi all
Sorry if this has been asked before but cant seem to find anything on here or anywhere else online
I had codes come up on my car which where p0272 and p0266 after taking advice i sent my injectors of for testing once there the company said all 4 were on their way out so got them replaced with refurbished units once fitted following guidelines on here and where coded in once installed.
After doing this i went for a test drive and there was no power like in limp mode then the engine management came back on after checking the codes again they are the same codes as previous
If anyone has any advice on this issue it would be greatly appreciated
Thankyou in advance stay safe everyone
bembo449
gainsborough , lincolnshire
you really should have spill tested you injectors before doing anything else pal , this is pretty much going to show any issues with them , it reads like the injectors aren't your problem ??
N
Nashley11
C class 2009 2.1l
Hi bembo449 thankyou for your reply in my untrained opinion i also believe the injectors wernt the issue in the first place but as directed by a local mechanic and united diesel changed them all my only issue is now after spending £700 on injectors i am no better of than i was previous so just trying to figure out where i go from here as i cannot keep throwing money at it just hoping something fixes it which seem the way the mechanic i went to seems to operate
bembo449
id play hell up pal , they are clearly clueless OR like extorting money for nothing out of you ! did you ask what the codes were for ??
mioba
Nottingham and Köln
welcome to the forum. do stick around.
take a step back. Who diagnosed the fault as being injectors. This is a skill requiring competent people and quality code readers.
If it was a diy job then i say its mis diagnosed.
over many years I learned to pay once pay right
For the un experienced cheap code readers are only good too see whats going on with the car, for diags its a can of worms.
you need a competent merc specialist with star/xentry diags not a run of the mill garage. Run of the mill garages are good for purely mechanical things, pads, disks, some suspension parts, changing halogen bulbs etc.
V6Matty
Newark, Nottinghamshire
We’re the replacement injectors coded back to the car, it won’t be the root cause but will ensure that your not causing yourself further issues and red herrings.
As above though I think the codes are only a part of the issue, you need to be following TIPS in STAR to go further into the issues and find the root cause, probably a couple of hours in total to find it.
hmang
he says they were coded in .
what does ....'on their way out ' mean ?
theyre either in spec or not surely
V6Matty
Possibly meant they were leaking already maybe not bad but would only get worse, so “on their way out”
N
Nashley11
C class 2009 2.1l
Hi thankyou all for your replys i live in mid wales so have only had access to local mechanics i have no objection to drive it to a Mercedes dealership but am worried i will cause more problems if not its the first thing ill do
Thanks again
hmang
Thanks again
what response from the people who relieved you of £700 ?
N
Nashley11
C class 2009 2.1l
Hi hmang i havent contacted them yet as wanted to make sure it was another issue rather than just complain for the sake of complaining
N
Nashley11
C class 2009 2.1l
Hi all today i have been sat in mercedes letting them have a look they had said the injector values hadnt been reset once done reset eml but still no power and suggested they needed further investigation at £156 an hour and cound run to 4-5 hour which i cannot afford at the minute they have suggested a vacuum problem but there are no codes to suggest this any one got any advice as i am absolutely lost in it all now
Thankyou in advance
mattkh
England
A160 W168 1999 1.6
........Thankyou in advance
Please tell me more about the engine.
Engine code
Mileage
Gear box manual or automatic
Did you take the injectors out to send them for testing. If it was you, did you see any blackness in that area.
What you have had done to the car from the time you had the car.
N
Nashley11
C class 2009 2.1l
Engine code
Mileage
Hi matt
My car is a c220 2.1 litre with 120 thousand on the clock
I only bought this car in december so havent done anything myself
I changed the injectors no black death was very clean if im honest
I sent injectors and got told all faulty so got a full set of refurbished units once fitted had them coded in and once on a drive there was no power my next step was to take it to mercedes for further investigation to be told the old values needed deleting and once nothing changed after that they said theres no more faults showing on the car but still no power
And for them to start an investigation manually would set me back 156 an hour and as previous i cant afford to pay that rate hourly with no end in sight
N
Nashley11
C class 2009 2.1l
Hi matt
Also a manual diesel
N
Nashley11
C class 2009 2.1l
Also forgot they said i had a rip in a vacuum pipe but they fixed that
Kev555
N.I
December is a bad month to buy a Mercedes LOL. I bought my Vito in December too and had similar issues to you Nashley. Thankfully a set of injectors cured mine after pulling my hair out for a few months:rolleyes:. Recommend you go to a good merc independent to get that issue sorted. It might be a wiring issue but who knows.
N
Nashley11
C class 2009 2.1l
  • #18
Hi everyone bit of an update i decided to look at the airfilter after reading online and it was filthy took it for a drive without it in and full power restored as its saturday cant get a new one today so blew the old one out refitted and now full power no lights on the dash so unsure if all along was a air filter problem very confused but happy at the moment
Taffy7hfa
Oxford
Happy Days ! :) sounds like it may be in need of a service.
ajlsl600
france
Lucky you. Hope thats it .dealer f useless should have been checked before hooking up diagnostics along with other "basics" and if solved maybe you learned something about avoiding dealer "fees "!!
