Injector seals
James Blyth
E Class 320cdi 2003 89k miles avangarde 6
What sort of mileage do injector seals start to wear on e320cdi 2003 .My car has 89k on clock ,never even thought about it till start doing a little digging on these cars ?
Taffy7hfa
Oxford
Hi James, typically around the 100k mile mark, but its a bit of a how long is a piece of string question, I always run them with the engine covers off and check every now and then. As well as "chuffing" its not unusual to have an unpleasant smell in the cabin.
James Blyth
James Blyth
Thanks mate ,pick car up wed will have a we look ,engine sounded fine gave it a quick rest drive so hopefully fine
What area do you live in ? (Update your user details to show it ) that way a good independent MB Indy can be recommended by other members
James Blyth
James Blyth
Thanks wighty,I'm sure put it In my profile ,will check again
M80
Derbyshire
As above, how long is the string.
It's not so much wear, they can decide to pass when the corrosive gasses have tracked a route across the copper washer and seat. Then there is likely to be the smell and associated chuffing.
Where possible remove cover and with torch inspect around the injector bore for black deposits. If it's bad it'l be apparent w/o a torch.
Trouble is some covers, like the 639 are bolt on. There I lift the bonnet and smell and listen.
The repair is somewhat involved but not scary, or overly expensive.
James Blyth
James Blyth
Will engine management light come on if you have injector problem
M80
Derbyshire
Not for black death,
other more significant issues yes. Then you might even fine the car smoking, running woof woof, and even failing to start.
James Blyth
James Blyth
I know mate thanks read a lot about it and overdosed on youtube ,the has a full service history and engine bay no discolouration on cover which is good sign so think should be fine .Will check visually when pick up car .
James Blyth
James Blyth
Had a look at injectors ,nice and clean no black death lol
James Blyth
James Blyth
it can happen at anytime pal , only real way to be sure is to have / do them so you won't have to ;)
Fair enough mate ,car is running smoothly,pulls like a train and only 89k on a 2003 .Will keep an eye on it and any sign of trouble will change all injectors and seals
jj1975
essex
w203 c220cdi 2002
Hi there my C class 220 2002 first injectors seal give up 2 months ago 200k miles
James Blyth
James Blyth
That's amazing hopefully mine has a few miles left then .
Frontstep
T210 320cdi
I don't know if the corrosion tracks from the outside in or vice versa but I suppose you could spray some ACF50 or similar around the injectors and glowplugs as a preventative measure every now and again.
It might make them easier to remove if you have to in the future.
Its supposed to be good to 200 centigrade.
jj1975
essex
w203 c220cdi 2002
Still is not big deal if you change the seal on time
James Blyth
James Blyth
  • #17
I've no idea mate ,its running fine at the moment so just going to leave
Frontstep
T210 320cdi
Its just a squirt if someones in the area.
