oigle
- Mar 15, 2005
- Age
- 83
- Location
- Redcliffe, Queensland, Australia
- Website
- members.optusnet.com.au
- 2003 ML270 sold but not forgotten. 2022 Kia EV6 RWD LR
well i did the hard part of this on my car over the bank holiday. at least 1 flap was disconnected from the linkage and the rest were sticking due to the cr@p from the days when the EGR valve worked.
i was UNABLE to aquire an M16 tap though, so instead i opened up the holes a little at the outer ends (that are usually tapped) with a stanley knife blade, then got some 15mm copper pipe blanking ends that plumbers use, and glued them into place with JB weld. now i need to get the resistor to delete the motor as its held in with a cable tie (for easy removal) against the manifold mounting metalwork, so i suspect it may jam the motor a little and put it into limp mode. only done 4 miles in it since doing the mod, but all seems ok so far!
Hope that is very good glue. You are dealing with quite a high air pressure inside the manifold which could blow them out.
