Inlet sprocket gear for w203,m271
Remmy mumba
Mercedes w203,m271 engine.year 2006
I have a w203,m271, which jumped timing ,and we noted that the inlet sprocket gears teeth were gone,of which we had it replaced.but the problem is that the chain is making noise,and just discovered that it get loose in between the two sprocket gears.we have also changed the tensioner
Hello and welcome
All too common on an M271 unfortunately :(
star
Reading
Smart + others :)
Needs a chain too.
R
Remmy mumba
Hey all am new here.
I have a Mercedes 2006 model c180,w203,m271 which skipped timing upon opening we discovered that the inlet camshaft sprocket gear had lost its teeth,of which we replaced it.but immediately after replacing it,the vehicle started making noise like a it were a diesel engine,after openning the top we found the chain loose in the middle between the two camshaft sprocket gears.
What could really be the problem?
As per above, no requirement to start multiple threads, it just makes it confusing
star
Reading
Smart + others :)
And don’t drive it, because if it snaps and bends valves, you open a whole new world of pain.
As above, the normal fix is replace both sprockets, chain and tensioner with new.
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
Go back to whoever replaced the sprocket, & ask why he didn't change the chain at the same time.
R
Remmy mumba
Thank you all for your answers,we changed the all timing system,and the rattling sound is gone but theres a new problem,code P0335.the vehicle is back firing and stalling if at all it moves
Sounds like the timing is off
R
Remmy mumba
Hey everyone,i have just learnt that the inlet sprocket gear locking pin,was off en the time we tried to put on TDC the inlet cam never moved for about 10 or so degrees.after giving it a complete 360 turn the cam aligned. Am now worried,
Is it possible that the valves can be okay?
Now that its timed, do a compression or leakdown to confirm if the valves are seated or not.
Turning by hand they should be fine.
R
Remmy mumba
  • #19
Hey all hope you all great, we have taken out the head and just discovered that the head is richly black,and the valves are closing very well.
Is it possible that the cylinder head gasket would allow air in when not tied correctly?
No. Head gaskets always leak from a high pressure zone to a low pressure one. Generally that means from the cylinder to anywhere else. There are usually lots of other issues if that's the case.
