Intelligent lighting system. R231
Bay Leaf
Stockport
SL 350 R231 2013
How does this work. Before anyone says it's in the hand book or command center, I know. I've set the headlights to auto whereby if you have them on main beam they will automatically dip when there is an approaching vehicle. However since I've done that I can't select main beam manually their on dip all the time. I know the easy answer would be to set them back to normal mode, but I'm sure there must be an explanation.:confused:
You either turn it all off in the dash cluster or just turn your lights to 'ON' instead of 'AUTO' ..... I agree with you especially when you're on a narrow B road & you want your main beam on but are going slower than 30/35 mph
rorywquin
North Yorkshire
An old B-Class.
I think that speed-limit only applies in built-up areas......I live in a rural area and have not noticed that going slow does not switch to high beam.
ILS won't switch to main beam in a well lit built up area anyway, what ever speed you're doing. ;)
My car definitely has a minimum speed before they switch over to main beam .....
Wearsafoxhat
Sunny Hampshire by the sea
I think it is more two do with light. In town our main beam very rarely comes on but in open countryside it works perfectly well, at any speed. ( MY19 V220).
rorywquin
North Yorkshire
An old B-Class.
@EmilysDad
The newer cars use GPS to assist ILS (LED version), e.g. knows built-up areas and when approaching a roundabout the beams spread etc. As soon as we have a dry evening I'll take mine out for a test run but I've never felt the need to manually use high beams when on narrow & slow country roads.
