Intermittent intermittent wipers!
Oldspanners
Normandy
C CLASS 2004 C180
Noticed today that the wipers on my W203 C180 went on to intermittent speed when on the first speed, not intermittent, as the rain eased and the auto headlights had switched on.
Now as far as I can see from the spec of my car it doesn't have rain sensing wipers and has two sensors on the windscreen. The windscreen has been replaced at some time.
Just curious whether this is the start of a problem or did something need reset when the screen was changed sometime before my ownership.
DelDrew
2007 CLK280 Sport Convertible
Probably a faulty stalk, a common problem.
Sent from my iPhone using Tapatalk Pro
Oldspanners
Oldspanners
Normandy
C CLASS 2004 C180
Certainly a distinct possibility but I got the impression that the speed of the wipe was proportional to the amount of rain and when I changed the speed everything went back to normal.
Strange.
Ken_R
Worcestershire, UK
W203 2006 C230 Estate
Think I've got the gist of the question.
Mine, on slow/first (constant) speed will change to intermittent when I come to a halt.
Similarly, if set to intermittent, then when low road speed/coming to a halt, they will stop.
All resumes as set when moving off again.
Oldspanners
Oldspanners
Normandy
C CLASS 2004 C180
Brilliant, Ken exactly that. It's been bugging me on and off (intermittently) since I got the car over two years ago, I read the instruction manual and lots of other advice about it but could never find a satisfactory answer.
How did you find out?
Ken_R
Worcestershire, UK
By looking at the windscreen (intermittently):D. Damn clever these motors! I can remember a vehicle, I think it was a Scania where, if you wanted to change the 'delay' in the Intermittent 'wipe', then one switched the wipers from intermittent to off, and then back on again. The 'delay' [between the actions] was then stored as a 'time function' for each additional 'sweep' [of the wipers].
Not that I ever found that it actually worked.:rolleyes:
EmilysDad
Bury Lancs
ML350
VWs do that ....
Oldspanners
Oldspanners
Normandy
C CLASS 2004 C180
Ah, that's what I was doing wrong I was looking through the screen!:)
Anyway both you and the wiper motor are way cleverer than me.:confused:
Thanks again.
