Is there water in this trans fluid ?
Kodyeml270cdi03
Ml 270 cdi 2003
Does this trans oil look full of water ?
joderest
ML270 2003
bit difficult to make out the pictures.
Please correct me if i am incorrect, but that MY ML270 does not have transmission oil cooler within the Radiator, its separate on the outside, hence very difficult for water to enter gearbox.
Oil should be just oil coloured, depending on what oil was used, either red or gold. Perhaps its just well past its sell by date.
M80
Derbyshire
Remove some into a clear container.
Let it stand a while and see if it separates.
spenttherent
E220 Eclass estate 2008
Did read a test somewhere that said, if you pour some on a hot pan and it splatters, then its got water in.
Not sure if that works
Jim2
1st Merc 2010 E Class W212 2.1 CDI. 2nd Merc 2014 E Class W212 220 CDI 3rd Merc 2018 E class W213
There are two radiators at work, one for the engine coolant , and one for the transmission fluid. In earlier automatic MB models , the engine rad leaked into the trans rad, and in several cases before it was flagged and the rads changed, it deatroyed the transmissions. There is a test strip available which will react to water by changing color when it comes into contact with it. Google water miscible test strips for ATF.
Doug1234
Bedfordshire uk
OM642 Jeep Grand Cherokee
Yes that test will work , people that run veg oil use the same test.. hot pan and about a table spoon of oil dropped in.
It will fizz and pop if water in it.
YES!
My milkshake brings all the boys to the yard.............................. :)
Jim2
Yes thats true, but both shared the same radiator, with a partition seperating them, and this partition used to leak water into the trans cooler, and from there directly into the transmission...it was a major flaw in the radiator itself..Valeo ones, I think , but google MB faulty transmission radiators , and there plenty of info on them. It has not been a problem for a Nr of years now, since they changed to a different Radiator manufacturer .
Jim2
It sure looks like its contaminated with something, thats a completely unnatural colour for ATF. I've never seen ATF fluid that color, you will get old fluid which was originally red, but with old age and burnt particles from the trans itself, will be almost black in color.....
