Is this a jacking point to lift front of A Class A 160?
Submariner1
Windsor Berkshire
CL500 2009 5.5
Is this hard rubber/ plastic block an official jacking point suitable to lift the entire front of the A160?
Circled in red.
Would the position of this axles stand, be OK to take the weight ?
Or more conveniently can one put the axles stand under the front trailinq arm, as in the picture if used with a non leaking jack ... as a failsafe?
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Yes its a jacking point. You don't want axle stands on the front suspension as its not level and can move . Look for main chassis part thats structural and flat. Top photo looks OK. Leave the trolley jack in a good place also .and place a wheel under the sill. Last thing you want is to be crushed .
Submariner1
Submariner1
Windsor Berkshire
CL500 2009 5.5
Thanks much appreciated
ajlsl600
france
I have the 170. I jack on the big plastic round pads just behind front wheel and in font of rear.then I block on some oak blocks I had made for the job.
ajlsl600
france
I am 2/3 way thro building a steel platform and staircase then it's cars, all, up on lift for annual look around. I will be making 4 no1.2 m axle stands to keep car up so lift can drop to allow muffler, prop out of clk to change center prop bearing
