It will be a Bottle of Red tonight!
marlowboy
Hi all, SL350 R320 with a solved problem!
Had the Abs and a couple of other warnings come up on Dash before Christmas, took her for a Starr as a Chrissy present and was diagnosed as the rear speed sensor. They, a well known Indy quoted £450 for Sensor and Ring. I know you are supposed to be wealthy to own a Mercedes but....
Finally weather has improved so “whipped off” the Sensor, thought if it works, wonderful, well it fought back a bit but don’t they all, and replaced via EBay for £14 and...............no warnings up and no stored problems!
I’m sure the other side will now go bang but I’m happy and a tipple this evening, or lunchtime is in order! HAPPY!
vtaylor78
Northamptonshire.
Great result , for the sake of £14 you had nothing to loose.
V6Matty
Newark, Nottinghamshire
If you can, go to Waitrose and look through their bin ends (if they still have them at your store), I’ve found many a nice bottle hidden in there and never more than £16, not bad when it likely started off at £30-35,
Shutup!:)
In the early 2000s my wife used to do a regular chunnel run with friends for a day of shopping in Calias - even there, wine was really good value and decent stuff was very affordable.
I used to do that regularly, out at about 20:00 and back just after midnight (then a 4 hour drive back to South Wales)
Oldspanners
Normandy
C CLASS 2004 C180
The problems start when you get confident and start buying the wine before the repair:rolleyes:
M80
Derbyshire
An iCarsoft would've diagnosed that,
while I don't sing their praises as much as the mojority, spending a fraction of your saving on a V2 would save you a trip to the Indie next time.
