Just Bought a C280 - First MB in 27 years!
GB Classic
Berkshire
2004 CL500
Hello all
This is the first time I have owned a Mercedes since 1980 - when I had a 1965? 220S.
Many cars have gone through my hands since then and for the last 4 years I have been driving a 1990 Granada Scorpio 12v which has now seen better days despite having had over £3000 worth of repairs since I have owned it.
For the last 2 weeks I have been looking for a suitable car to replace it with. I like the look of the C class and wanted a rear wheel drive car which would have good performace and handling. There was no way I would look at BMW (a story I may tell later) so really it had to be the Mercedes.
I went and looked at quite a few C280's registered between 1994 and 1996, and priced between £2000 to £2750 but many weren't worth a second look for various reasons including rust, very high mileage & bad oil leaks et al.
On Wednesday I found a 1994 C280 Esprit at a local car dealer advertised at £2495. I took it our for a drive and it seemed fairly quiet and smooth compared with the other ones I had driven, and the 84000 recorded mileage seemed to tally with the service book. The bodywork seemed to be in excellent condtion and was finished in Imperial red. After a bit of negotiation I paid £2000 for it and picked it up yesterday with a years MOT on it.
I don't really know what to expect from it but after driving about 100 miles today I think that there may be one or two things awry. The handling is a bit twitchy and at times vague needing a bit of correction here and there on camber changes and there seems to be a little play in the straight ahead position. I also find the car turns in very quickly. The tyres are Goodyear Eagles - Is it right that they should be 33psi front and 36psi rear?
The brake pedal also seems to have quite a long travel compared to the other cars I have driven but they do seem to pull the car up well. I noticed that there was an advisory on the MOT that the rear pads are getting low and wondered if it could be this? If it is - is it an easy job to do?
The other thing I noticed was that under hard acceleration the gearbox does seem to whine rather although probably no more than the others I have driven and is not exactly loud so assume this is normal but please correct me if I am wrong.
I am sincerely hoping I have not bought a lemon! as apart from these niggles I am very pleased with this car and I hope to enjoy many miles in it.
Any comments appreciated
Ron Palfrey
C280 Elegance 1994
Welcome to C280 ownership - Lovely cars!
Hello Phil,
Welcome to the forum!
You've done more or less the same as I did 2 1/2 years ago.
Don't forget the car has a steering box, not rack & pinion, so expect a little play there, especially in the straight ahead position. The MOT should have picked up any problems. I run mine on Michelin E3A Energy tyres (last well and handle good too). Last car I ran on Eagles turned in quickly too, but they held on well. I think you'll get used to the turn in. When my son drives my C280 I notice he's surprised by the fast steering, and he's used to a quick tuned and lowered 306. Watch it if you have your best tyres on the front because the back can get twitchy in the wet! All predictable though. As for tyre pressures, there should be a sticker/transfer on the inside of your filler flap with the recommended pressures. I prefer to run mine at 32 front, 35 rear so yours are about the same.
Rear brake pads last quite a while, 2mm thickness is the minimum thickness but the pad wear indicator actuates at 2.5mm. I doubt if normally worn pads would affect your brake travel as the fluid would take this up in the hydraulic system. Probably the travel is just different from your Ford, give yourself time to get used to it.
Gearbox? Well mine is an auto and is quiet. Is yours a manual? Then perhaps someone else with a manual will come on and comment. As long as there are no grinding noises again I would give yourself time to get used to the different features of your "new" car.
I've had absolutely no trouble from mine in the 2 1/2 years I've owned it. Had 80k on the clock when I bought it with full MBSH, but has done 102k now and I do all my own servicing. Change the oil and filter every 9k (use quality oil & MB filter), brake fluid every 2 years max., coolant every 3, plugs every 40k, air filter every 54k, auto transmission fluid & filter every 36k, lube that big single wiper (under the turtle shell cover - dead cinch to do), and hopefully, like me you'll be well pleased with your purchase.
I should buy yourself a Haynes manual (No. 3511). It doesn't cover the C280 engine, but is useful for everything else.
Hope you get on OK, any problems use this forum, the members here are very helpful, and some are very knowledgeable.
Best wishes, Ron
G
GB Classic
Berkshire
2004 CL500
Hi Ron
Ron - Thanks for your detailed reply and words of encouragement. I feel quite reassured from reading your post. I think a lot of my quibbles are down to me not being used to the car yet. Mind you the more I drive it the more I am liking it and I have been driving it all day! :D
Many thanks for all your advice about the points I mentioned and I have taken them all on board and will be giving the car a thorough going over in the next week or two. I have just ordered the Haynes manual.
By the way it is an automatic and the noise I mentioned may not even be coming from there at all - in fact I think it may even be an intake whoosh I am hearing- it really is hard to tell where its coming from.
Jb - methinks the Granada will soon be forgotten!
Anyway here is a link to some pics I took while I was out todayhttp://www.cig.canon-europe.com/ph/AEG/RequestViewAlbum.do?i=kJmfKH0TLC
Ron Palfrey
C280 Elegance 1994
Phil,
Thanks for the photos. What a beaut! Looks an excellent buy for £2000. Clean as a whistle - even under the bonnet - obviously been looked after. I think you've done extremely well with that one. Good colour too.
Ron
The pictures are nice, and the car looks good, as Ron said, very clean and rust free, always the best starting point.
Welcome to the forum, any points that you are not sure about, just ask, we have many of those cars here.
