Karcher died
Big Gordy
Airdrie
Previous c200k coupe, c350 petrol coupe, clc220d, e350cdi coupe present E220d coupe 2015
Hi guys any help appreciated.
my karcher pressure washer died. So that’s the 3rd one I’ve had so I decided to try a Titan from screwfix. Same spec half the price, but unfortunately my karcher snow foam gun doesn’t fit and it doesn’t have a screw on fitting. Can you get a converter to go from karcher fittings to Titan.
Gazwould
C250 CDI
Would be handy to know who makes Titan .
Chrishazle
Nr Ashford, Kent
It's Screwfix's own brand, bought my SIL a big SDS hammer drill (mains) some years ago, it's had much use and been excellent.
mioba
Nottingham and Köln
Was it a small karcher. I have always gone for thier higher priced machines, 200-300 range. My first lasted 16 years and only died as a bearing died, it puked oil. It was old enough to make getting parts not possible, plus I am not a fan of opening machines that are electrical where water is involved, you can never get them sealed right again.
rorywquin
North Yorkshire
An old B-Class.
Do you leave it in the shed in winter?
Big Gordy
Big Gordy
Airdrie
I got caught out with that before. The water in plastic 90 degree outlet bend froze and cracked it. I do keep it in the garage but I wrap it up in an old picnic blanket. This one started loosing pressure constantly pumping even at idle without trigger being pressed. Then it just pumped constant with no pressure. Karcher repair guy said bin it not worth repairing.
Big Gordy
Big Gordy
Airdrie
I’ve had 2 small ones K2 I’ve got a B403 series needs repaired and a big K5/12 professional not working. Bought the Titan as I have a Titan wet and dry vacuum I use for garage car and diy clean ups.
Big Gordy
Big Gordy
Airdrie
I bought a Titan wet and dry vacuum for garage and car cleaning its ace
Big Gordy
Big Gordy
Airdrie
EmilysDad
Bury Lancs
ML350
My last Karcher died too ...Who'd have thought that the inside of a shed could get so cold? it pumped but spewed out as much water from its base as it did from the lance. Stripped it down so far but couldn't see anything obvious, so bought .... another Karcher so that the accessories I already had would fit.
Karcher do a repair service but I didn't think the cost justified it, hence my new pressure washer.
V6Matty
Newark, Nottinghamshire
I’ve bought a Titan pressure washer too, but only because instead of £80, I got it for £55 due to box damage, used it a couple of times now in anger and it seems to be very good, now I just need to purchase a snow foam Lance for it, though the current garden hose fed one I have is still usable, just seems to use a little too mu foam solution for my liking
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
I bought an Evo System (Mitsubishi engine) and accessories for a project I had back in 2013 and consider it best money well spent on shop tools in recent years, the jet wash unit runs at 175 Bar (220 Max) and will take the top coat of paint off the car with the wrong setting! And it brings brick, block and stone paviours up as new effortlessly, It also has a built in detergent/treatment/snowfoam delivery settings but it is rather noisy :eek::)
www.W140.co.uk&www.r129.co
