key fob for W124 1994
280ET
Hi i have mercedes 280 E station wagon 1994.
There is a 1 proplem, it´s the central locking system, my battery in the key it self was finished and i changed the battery, but i was more than 30 second so the original securiti system, lock the engine it will not start and the sensor in the drivers door does not work also the sensor in the trunk.
So i need help to code the key to the car,can anyone help me :rolleyes:
p.s is there any kind of a treatment or like steps to code the key back to the car.???
Is the key sending out a IR signal, try in front of digital camera
Press any button and put key into ignition within 30 sec and turn to 2
Welcome to the forum
280ET
yes i can get a red light (signal) from the key, and i have try to push 2-3 times on the button on the remote and put the key in the ignition and turn to position 2, but nothing happend.
The red light does not mean that its sending a IR signal
280ET
ok i know that the red light show if the battery is ok,but can it be that inside the remote, is some wire not connected. because i have couple times dropped on the floor:confused::confused::Oops:
What type of key is it, flip out or just a key fob
280ET
yes it is a flip key
280ET
no this did not work :(:confused:
kth286
E320 Coupe 95
To synchronise the system, do as follows:-
1. point transmitter in key to the door receiver.
2. press the key button briefly.
3. go to ignition switch and turn the key to position 2 (this must be done within 30 secs of above).
4. the infrared remote control is now operational again.
280ET
key fob
no i already try everything, like point to reciever and lock the doors inside the car, but nothing works i am going crazy because of this stupid original securiti system. i think that the answear to my proplem is that i have to order a new flip key from the benz factory in germany.???
lakeside
S124/1996/280
There are two types of infra red systems on w124s, with different option codes. The procedure for synchronising is different. One is as described by kth286 above, and applies to option code 885. The other procedure, for option code 880, is: aim transmitter at drivers door LED. Press button for 5 seconds. Go round to passenger door, unlock with flip-out key.
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
Interesting! Some of the RCL systems seem to have an alarm & immobiliser and some don't. I wonder if that's the difference between the two option codes?
Nick Froome
www.w124.co.uk
lakeside
S124/1996/280
This may be of use:
  • 80_420.pdf
