Key Fob Problem
dazzawm
CLC200 2009
I have a 59 plate CLC200 CDI. I believe the key is knackered as I have changed batteries and it does nothing. It wont release steering lock or 'release' anything like it would normally do when I insert into ignition. Is it something I have to purchase from Mercedes at a cost of around of £300 or will one of Ebay or alike work? Thanks
AMGeed
Poole, Dorset
S204 C180K
Does the key open the door with the remote?
You don't need a battery in the key for it to release the steering lock.
I have a feeling your problem is not the key but your ESL (Electronic Steering Lock)
Have a look at this video and see if this replacates your problem
In the meantime, you may want to get another key from the main dealer. You'll need your V5 and some ID to order it and its around £240 last I heard. A second key is pretty vital if you lose your only one.
D
dazzawm
CLC200 2009
The remote does not open the vehicle, no.
AMGeed
Poole, Dorset
S204 C180K
^ In that case, the PCB inside the key is probably damaged.
Where is your location as the key can be repaired?
Birmingham, London and somewhere in the N East can repair the key.
D
dazzawm
CLC200 2009
AMGeed
Poole, Dorset
S204 C180K
The second link will travel from London to fix the key. No idea on cost though.
D
dazzawm
CLC200 2009
Ok, I went to Mercedes and had to order a genuine replacement that now works. They said it didn't need coding so when I returned to the car it worked fine. I want to get the old key repaired so I have a spare, is there anywhere that will do a postal repair? I tried those 3 links and they seem to think it can't be repaired and I will have to pay another £240 from Mercedes if I want a spare. Anymore ideas please?
