Malcolm, just checking have you received my key. eddie
Yes I noticed it was a 3 button one, what is the third button for ? also that key seemed to drain its battery quite quickly, I assumed it was due to the broken case and maybe a bit of damp getting into it.Yes its here and does look to be in goodttont condition, If I have the courage to go into the workshop I will check it out, Like you other one it is a 3 button key in a 2 button case.
PM sent with address
Hello Malcolm. Just want to know if you have received my key ?
Yes I have it and will do it later in the day, the case is scrap and I will give you one a little better, it really needs a new case, you can buy them on Ebay later on and easy to fit.
hi Malcolm, I assume you will be sorting mine out at the same time, but a quick question for the future, how do you remove the circuit board from the case in order to fit a new case, it looks like you have to slide something thin down the side of the white section in order to unhook its clip, but im not to sure, hence the butchering of the case from the key you have.
Not such good news on this one so far, I have done the locking one OK, but for the unlocking one the PCB is badly damaged from contamination from the very badly spit case, I will give it a little more time later.
Not yours Sirwho's one is that Malcolm ?
The problem with a key that has a very broken case, moisture and dirt gets in, the PCB's are dual sided coupled by through plated holes, and these can go open circuit, it is a pig of a job testing these holes, the are about 70 of them, I will give this one a little more time.
As I have said the locking now works OK, but the key may only have a limited life time.
If you key fob case is badly split, then get a new case from Ebay
Y
just read this back, sounds very selfish and un careing. very sorry to the key owner, and hope Malcolm can sort it for you.
Yes you are right. I will order the casing today and will transfer PCB as i get the key back. Thanks for your efforts and time.
I was going to give you a reasonable case with just a tiny split, if I can fix the unlocking, you should hold on a while
