Does anyone know what the legal position is in these circumstances please?
Sometimes jobs don't go to plan, it's not the garages fault that your injectors are seized in the head.
It's your car, and the cost of repairs to it are your responsibility.
It may be his car, but the acid test is "who did it"?
He was quite happy with the car until the events above developed the way they did. The garage, by persuading him of the need for the work, not warning of this possible complication and then not completing the work as agreed, have left him worse off than when he started.
I'll stick with the points made previously.
Xtractorfan - how do you remove a stubborn injector please?
|I have some sympathy for the garage that did it. In their minds they tried to be as honest as they could but on the other side, their skills are clearly lacking if
a) They didn't foresee and forewarn that this could go pear shaped.
b) They couldn't sort it (when others on here say that it is sortable).
If you go legal, then the answer is likely to be bring it back and we'll fix it. I wouldn't want to do that.
So if it were mine, I'd cut my losses and get it fixed elsewhere.
And "The garage are clearly correct in their diagnoses, otherwise the injector would have come out without any issues.
This blame culture we've sleep walked into has to stop". (Dave Brooker).
To take these comments at face value would however suggest a position that acknowledges that whenever the man in the street accepts advice from experts, which goes wrong and leaves the individual worse off and the expert can walk away from the mess, then because they are the owner of the property it is purely the owners problem and liability.
But we all know that repairing complex cars is not a precise science, do you think it's correct to try to use the law to force a garage to repair the unrepairable?
If while repairing a car, the job turns out to be more complex than at first thought, why should the garage not charge for their extra labour?
It's OP's car, and as such problems with it are his responsibility.
Don't you think that it would be fair to point out that it may not be straight forward in the first place,,we all know that injectors can be difficult things at times.
I said it earlier in the post that I point things out to the customer, either saying leave it,,or if we try there is the danger of XXX.
If the garage had the correct tools, then maybe they would have done a better job
I am not sure I entirely agree that the garage is at fault here.
Something similar happened to me a few weeks back.
I took my car in for them to check a scraping noise at the rear offside., they said, that will be the hand brake shoes sir, cost you £xx think it was something like 80. Received a call from them a bit later. Hello Sir, we have taken your brakes off and found that who ever replaced them before had not secured them in correctly and they have scored the drum surface to a dangerous depth.
Total cost ended up £330 for 2 new back disks and shoes. As the brake shoes were badly damaged, they could not possibly replace them to the same working manner as when they took the car off me. So I am more than happy that a £80 job tuned out to cost me a fair bit more.
All work is undertaken on the premise that nothing else is broken and that the items require fixing are replaceable. If they had called me and said, sorry sir the disk took us over 2 hours to remove as it was rusted in place, I would deem that acceptable.
