leaking auto box
bobby b
Hello all, have found the source of a leak from the auto box on my W211 [2003 classic]. It's coming from the selector shaft and was wondering what is involved in replacing this seal. Thanks
Xtractorfan
S class
The autobox doesnt have a selector shaft, its electronic and only has a wiring loom and plug into the box..the seals on the plug do leak..
B
bobby b
w211 gearbox leak
Hello again, can someone tell me what the small arm on the passenger side of the auto box is, because that's where the leak is coming from? Thanks
230K
Belfast
E300TD/1998/3.0 Diesel
Park?? I think that is the only mechanical control. I am in unknown ground here.
230K
MB TECH WARRINGTON
it does have a selector shaft on the side of the box, so take no notice of this statement above, the selector shaft seal is a common problem, the selector lever in the car is physically linked to the box via a rod and then the rod connects to this selector shaft, its valve body out job, not an easy diy job,
little tip dont believe everything you read, be it in newspapers or on here,
B
bobby b
leaking box
Thanks MB tech
Xtractorfan
S class
Oops a real mange tous as del boy would say ... its almost as bad as telling someone not to believe all they read and then writing it down..
MB TECH WARRINGTON
ha typical no it all eh, i said dont believe everything, not disbelieve everything, my advice was correct, im trying to help, ill give advice when i know, unlike many who think they know,
MB TECH WARRINGTON
Thanks MB tech
not a problem, any advice needed, ill be happy to help, expect about a 2-3 approx hr bill plus cost of seal, while you are there id get all fluid and filter changed at same time, oil is out anyway,
230K
Belfast
Hi MB Tech
What does the selector shaft select? Is it just park?
230k
MB TECH WARRINGTON
Hi MB Tech
230k
im pretty sure it will select drive, reverse neutral park etc physically via the gear lever, link rod then selector shaft, the tiptronic function is done electrically, hope this helps,
Xtractorfan
S class
Mea culpa..No what you said was u know it all.. I have never professed to do so. but i have come across guys who feel they do and their tact is to ridicule others... You have a business, ppl on here will use you if you are good at what you do...but once you start running down others it reflects on you.. when someone on here posts a reply and it is wrong diplomacy would suggest that the proper answer is posted and the snide remarks are left out ..as was 230k's post, polite and professional ..and it makes for a much happier forum.
B
bobby b
Hi mb tech, i've changed the electrical plug, the sump seal and filterand refilled the box but still the leak persisted. I've purchased the new seal for a few quid and was going to get stuck into it with a buddy of mine ~ what's involved if you don't mind? Also , how much should i put back into the box seeing as though it's been leaking
