Leaking diesel
fartypants
Isle of Man
Hi everyone. I got a puddle of diesel under my ML270 (WDC163113).
I have tracked it down to a unit near to the front of the injector rail. I was wondering a) if someone could identify this for me? and b) can I remove and bung the pipe to it while I wait for a new part to arrive?
Thanking you all in anticipation.
PJ
sixpack
Renfrew Scotland
2012 w212 220
Leak
Hi FP,
Yes you probably could just plug it, I think its a test point for fuel pressure. You could remove and refit the plug (push back the white plastic collar) to see if it seals. All of these pipes in this area are prone to leaks at the O rings, if you disturb them, they leak. Might be best to consider replacing all pipes (5 I think), about £70 from dealer. I had to to on my 2002.
Peter
fartypants
fartypants
Isle of Man
Thanks everyone, got the leak stopped. Will order new pipe and that fitting in the morning. Thanks again
star
Reading
Smart + others :)
quite common fault, if seals ok on ends, you can just swop whit plunger from new pipe, its the emergercy engine cut off i tink. :)
