Leaking rear axle seal at differential
pmay805
Raleigh, NC, USA
E500 2003 / Acura RL 2003
Driver's (left side of car) rear axle seal is leaking at differential. This is what my Indie told me. It's a 2003 E500. Apparently it has just starting showing signs of leakage. Is this a serious problem? How soon should I have it repaired? Is it a complex / expensive job? Thanks for any input. :D
Corned
East Midlands
2005 S211 E320CDI Avantgarde
I don't know how expensive/extensive the job is, but didn't your indie give you an idea at the time?
It's not a common problem, as this is the first post I recall on here mentioning such a thing.
How soon you should fix it depends entirely on how bad it is leaking. If it is a proper leak, then soon. The diff won't take kindly to running without the correct level of lubricant.
If it's just a slight weeping, then it's perhaps not so serious at this moment. One to monitor for a week or two perhaps?
y13pmc
doncaster
e320 04
hi part cheap as chips from merc took my indy about 2hours
pete
