LED pixel replacement in the Midlands?
DoctorBean
Derby
2002 E320 CDI Elegance
My clock and outside temperature LED display is wonky, apparently a known problem. I have been quoted by Mercedes in Derby just over £1000 for the replacement of the complete dash. They don't fix, they replace, is what I was told. He did say that there are companies which can fix it, but didn't say which.
www.actronics.co.uk fix them for £80 plus VAT and a good guarantee
Miffy
Bromley, London
CLK 320 CAB Elegance C208
I, along with others here have repaired the brocken lcd ribbons for the cost of an hour and £20
Sent from my GT-I9300 using Tapatalk 2
toby1
West Berkshire
IIRC there are instructions on BenzWorld
You can buy the kits on Ebay with all the instructions as Mark said £20
paul hayward
all MB sold..V70R now ;-)
well that sounds good as the CLK is a bit broken...one day will fix that as it annoyed the hell out of me:shock:
thanks malcolm.......:)
I love messing up other peoples good times, and I knew that Paul would not take it, I was hoping that you did not see the post ;)
BAZZER1
FERNDOWN DORSET
E320cdi AVANTGARDE SELECT
I had the same problem a while ago, bought the Ribbon Kit with fitting instructions on ebay for around £ 20.00 and with a bit of patience it took about 30 mins to fit new ribbon and problem solved, you don't need to be an expert to fit this part, just a little perserverance and make sure all contacts are in line and making correctly and you should have no trouble fitting this yourself.
Best Regards
BAZZER1
paul hayward
:lol::lol:....you could always run me through it though:D...its really one of those things that bugs me ,...even more so that the worn seat bolster:lol:
