LED reverse lights that won't upset the bulb warning system.
Droverunner
West Cambridgeshire
2007 CLK 220 CDi Sport. 2014 S-Max 2.0TDCi.
I want some brighter reverse lights on the Viano and LED seems the way to go. There are hundreds of them on Ebay but I want to do my best to avoid any problems with the bulb warning system seeing a problem with non standard bulbs. Any ideas or links for ones you know work OK?
M80
Derbyshire
Ignore it.
The 'Reverse Light' alarm will appear on the dash, but only while in reverse. I treat it as another indication that I'm in reverse, not that I need it.
rifiki
Worksop
CLK W209 W121190B
I had just the problem with my CLK. I got a refund. Had another go with ebay the LEDs were so badly made I did not bother to fit them, refunded.
Gazwould
C250 CDI
What bulb type is it ?
Droverunner
Droverunner
West Cambridgeshire
They look nice and bright! Are they a brand and do they upset the bulb warning?
Gazwould
C250 CDI
On the Merc no , but strangely yes on a Corsa D .
On the bay .
Craiglxviii
Cambs UK
Gazwould
C250 CDI
It's BS , you should see the claims for the headlight LED's .
Craiglxviii
Cambs UK
It isn’t BS. LED headlamps are limited to 1200lm by lighting regs. How they deliver that brightness is another question but still, peak luminous flux intensity doesn’t exceed 1200lm. So for a reversing lamp to reach 80% of that, when all it needs to do is either a) indicate to other drivers that your reverse gear is engaged, or b) provide enough brightness to use reversing camera at night- which I know from testing needs c.450lm- actually IS BS.
Gazwould
C250 CDI
What's the best way to measure their output ?
Droverunner
Droverunner
West Cambridgeshire
  • #18
I think they could make excessively bright reverse lights a major and therefore a fail by using the section.... Reversing lamp emitted colour or position not in accordance with the requirements
You might argue they'd be stretching the use of the phrase but may happen.
M80
Derbyshire
Maybe,
but position is as designed,
and colour is white, or warm white.
I've never had a comment at MOT.
Could they cite the lamps as not CE approved I wonder.
Droverunner
Droverunner
West Cambridgeshire
  • #20
Yep perhaps... I'm not that fussed either way just thought I'd see what regs subsection they might use.
  • Like
Reactions: M80
www.W140.co.uk&www.r129.co
