lost 1st and reverse
peter ford
2013 c220 cdi se 2.1 estate
here is to hoping someone may be able to help. got home from work today and my 2013 220cdi manual estate would not engage reverse. tried all other gears and it also will not go into second. all other gears look ok. i have had car 8 months with no issues. a 10000 mile warranty ran out 486miles ago :(:(
i have not seen any signs of leaks or strange noises etc
Have the gearbox oil level checked.
P
peter ford
simple as that? oh i hope so :)
Oldspanners
Normandy
C CLASS 2004 C180
I'd have a look at the linkage. If 1st and reverse are on the same end of the linkage something may be lose.
Does it make any difference if the gearbox is in S or C modes?
John Laidlaw
Wirral
Land Rover Discovery 4
I’m with Oldspanners on linkage check
star
Reading
Smart + others :)
No external linkage as such, one link only for all gears, it'll be internal inside the box, selector drum/fork fault.
P
peter ford
So apparently it’s a common known issue with this gearbox. 2013/14 was the last year it was used due to this issue. The spring for reverse is too strong and the force to overcome it and select reverse is enough to bend the gates on second. There is a retrofit ‘fix kit’.
It was in the garage two days and cost me £960 including vat. Ouch. But what can you do. All sorted now
John Laidlaw
Wirral
Thanks for reporting back, sure to help someone else down the line
