M112 misfire
Merrill
2005 - C320 - m112 e32
Looking for any input on what I can do to troubleshoot. Was driving, 53mph and 2k rpms engine started to misfire, ran codes and this is all the information the scanner gave me.
P0300 - random misfire
P0335 - crankshaft position sensor A circuit
P0306 - cylinder 6 misfire
P0303 - cylinder 3 misfire
P0304 - cylinder 4 misfire
Fuel sys 1 - CL
fuel sys 2 - CL
calc load - 64.7%
Ect - 180°
Stft b1 - 2.3 %
Ltft b1 - -0.8%
STFT B2 - 8.6%
LTFT B2 - 0.0%
MAP - 25 inHG
Eng rpm - 2025
Veh speed - 53 mph
Spark adv - 0.0°
IAT - 72°
MAF - 19.05 lb/min
TPS - 18.0%
Air status - off
Wondering where to begin?
Crank position sensor.
It's a known issue and you have a code for it.
M
Merrill
Yeah, is it as simple as replacing the sensor? Sorry if I should like a dingleberry or am asking a stupid question, to be completely honest i dont really know wtf I'm doing...
Yes it is. Single torx bolt to remove and if you're lucky the sensor will pull out. They can get stuck and if so can be a right pita to remove. Not the easiest place to get to.
Only use Bosch or MB sensors - cheap ones are trouble.
M
Merrill
Sweet! Thank you for the reply!
Yes, as above ++
