Magnetic Clutch
Yoggi
South Africa
Hi Guys
Can you buy the magnetic clutch on the supercharger as a spare part.?
On a C 230K 1998. Or how can i test mine it;s not kicking in at all
stats007
Hampshire
Looking
I think it's part A1110970128 which is about £200. There is an adjustment for the clutch via the centre screw though I don't know enough to recommend trying this. You could probably test the clutch with the engine off and applying the right voltage - I presume it works like a solenoid.
Y
Yoggi
South Africa
Thanks , Stats ,
Will welcome any other suggestions . The code read P0806
compressor output stage magnetic coupling
TSG
Coupling problem
Dear All;
I am new member at this club, and I am new as well of owner a Mercedes car, mine is C200 Kompressor Model 1998.
When I bought it I knew it has to be serviced. Especially the V-Belt of the compressor, But I have noticed a thing that the last cover of the coupling lost its 3 clips are lost. And the coupling only has the center screw is holding it.
So that mean when I turn my car on the last piece of the coupling is turning a half turn with a voice and stop and after a while it does it again.
I have attached to you a diagram picture of the coupling with some the problem explaining.
Shall I carry on by this coupling if the mechanic tried to fix and adjust the last plate of the coupling with another clips.
As I know that the coupling part number is: A1110970128
And the V-Belt of the comprosser is: A0119975892
Please advice me... as my car still have the same power in the big speed.
Regards,
Tarek
TSG
Problem In Coupling
Dear All;
Regards,
Tarek
Alex Crow
Super Suffolk
hello tarek, what problem do you have? is it the noise?
TSG
Thanks a lot Alex for the reply
Yes noise at the beging of the starting the engine up. and these 3 clipses are lost,,
