hi c220 51 plate ,changed the brake bulb as malfunction displayed 1 fault ,the display is still showing the error on the dash how do you erase this display?thanks.
This means that your brake pads have worn down to the limits, and the wear sensors have put the lamp on. You need to check if front or rear that are worn down
Mercedes-Benz Servicing, repairs, engine and diagnostics Wayne Gates - Mercedes-Benz, Unit F3, Phoenix Industrial Estate, Rosslyn Crescent, Harrow, Middlesex, HA1 2SP Tel: 020 8863 9233 Established for 20 years all vehicles washed and vacuumed.
