Mb Codes
nkombafm
Make me wiser
These code W202, W210, 123, 124, E200
How do you arrive at them? Sorry for taking your time am a new member and recently aquired my first MB
If you look in the link you can see all of the models,the numbers are for that group or chassis that various cars of a similar size was built on, the 124 for instance was built from 1986-1996 and the C lass started with the 202 in 1996 and went through to 2002 where the next one was the 203
http://www.detali.ru/cat/oem_mb0.asp?TP=1
NewMB
Colchester
Make me wiser
E200 simply means "Einspritzung" as in Injection. In the past, before MB switched to E and C before the numbers, it would appear at the end (ie 200 E), meaning the same.
N
nkombafm
Thank you for coming in to help make wiser
nkombafm
faugh a ballagh
Belfast Northern Ireland
i got a wee bit confused by the 210 and so on stuff, if for instance i see a part on ebay for example that says mercedes benz e 210 does that mean it will fit my car?
seen a load of things for an e class but it had w211 w210 etc which threw me a bit
If your car is a 210 then anything made for a 210 will fit
whitenemesis
CLS55 AMG '05
S denotes an estate (or stationwagon) strictly speaking my car is an S203 being the estate variant of the W203 saloon. No idea were the W came from...
100%Bitch
Norfolk 'n' good
Hence my little joke about the tailgate of an S210 not fitting a W210, Doh! Oh well, go back to sleep. :roll:
whitenemesis
CLS55 AMG '05
I was answering Malcolm and stating generally, I understood your "joke".......... :rolleyes:
whitenemesis
CLS55 AMG '05
As should have I :razz:
Isn't Malcolm popular?;)
No he is sleepy tonight :confused::confused::confused::confused:
Tel: 020 8863 9233
