MB option codes deciphering.??
nine468
Hi folks
Weve just bought a 350SLK 171 + it seems loaded with options, BUT itd be nice to know exactly what options it has, AKA codes on the sticker...[There are a LOT of them....]....
Are there any links anybody can piont me in the direction of to help de-code them...??
Thanks.
Just pop the numbers up here
N
nine468
Malcom.
There are a lot of them.
Thats why i asked for a deciphering guide.. So i didnt have to bother anybody else....
drdre78
london
mercedes c200 200
hi you can get data card for your car with vin number from wisnet
Alfie
Surrey/Cotswolds
www.comand.co.uk
Hi folks
Thanks.
As your car is an R171 then it will be 2005 onwards. So let me have the VIN and I can give you a genuine printout of the datacard showing the option codes and what they mean for your car.
Alfie
Surrey/Cotswolds
www.comand.co.uk
The codes on that site are wrong in some cases and there are loads of common codes missing. Use with caution.
386 - is phone pre-wire for instance.
No codes shown for the numerous audio/comand/ head units either.
Yes I know that that are many errors, with all of those sites, I now use the 2009 data from the VIN number but without it one cannot answer
drdre78
london
mercedes c200 200
hi if want give me chassis number and i email you the data card.or go into local mercedes dealer part deparment and i am sure they will print data card out for you
citroennut
ayrshire
hi guys and gals,
sorry to hi-jack this thread but my question is the same. 124 series, how do you know if 4/5 speed, gearbox no. is 722435 03 833424, 593 glass, is there a way to know if it is clear or green how green is it?, 341 additional lamp what and where?, 613 lamp unit asymetrical, l.h. traffic?, and did they not all have a lsd?
cheers
simon
hi guys and gals,
cheers
simon
722.4 means a 4 speed box,,the 5 speed was an option about 93 on,only on certain cars
593 green glass all round, heated rear window,single sheet safety glass, band filter
341 additional lamp,
613 LAMP UNIT, ASYMMETRICAL, L.H. TRAFFIC"
citroennut
ayrshire
thanks malcolm,
i didn't know whether it was the 4 of the last no. or the 5 of the first sequence.
593 gives two options on the printout, heat-insulating glass, all round, heated rear window pane (single-sheet safety glass), band filter.
green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (c 01.08.1972)
what is 341 additional lamp?
what is 613 lamp unit, asymmetrical, l.h.traffic.
and did they all have a limited slip diff.? or is it an option?
simon
thanks malcolm,
simon
It is too hard to work out some of these codes the
613 head-lamp unit, asymmetrically, L.H. traffic could mean the the car was used abroad for some time
341 on another site I found this,
additional turn signal lamps
