Merc A Class Smoking Dashboard
clkuk1
Hi everyone.
Need some help please !
My A class went into limp mode and behind the dashboard it started to smoke until the battery was disconnected.
Is this a common problem for A Class and is it an easy problem to fix ?
Any help would be great.
Thanks.
A Class 2001 edition.
drmw
Yorkshire
www.autonomed.co.uk
I don't think this is a common problem and sadly is not likely to be an easy fix.
Sounds like something is shorting big style under the dash, so first advice is do not reconnect the battery, rather find a local independent Mercedes repair shop and talk directly to them.
C
clkuk1
Thanks for the reply
I wonder if its a heater core issue but I certainly won't be re-connecting the battery as the car may catch fire.
How complicated is it to replace the wiring loom behind dashboard ?
nokia
London
W211 E320 CDI Avantgarde
have you got an aftermarket cd player?
I would remove the under dash panels, the connect up the battery while looking under the dash to see what is smoking
Triv
Bristol
A brace of s210 1998 e300 turborustbuckets. Toyota HiLux Surf kzn185 3.0L
I would leave it in a deserted car park and connect a really big battery to it and walk away.
:D
area51
Kent
Year2000 A160
Hi everyone.
Thanks.
Was it possible to tell which area of the dashboard the smoke was coming from?
The A-Class is known to suffer from ignition switch problems, maybe this has burnt out? (Happened to me on my Vauxhall Cavalier, some years ago. As soon as I turned the ignition on there was smoke coming from the ignition switch area).
Other areas to look; the connectors on the headlamp switch are known to get a bit warm/melt. The wiring loom to the headlamp switch sometimes chafes on the metal cross member behind the dash.
I wouldn't reconnect the battery without first removing the relevant parts of the dash to have a good look, as already suggested by Television. I hope this helps.
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Its not a bad thing, I assume you have Fire cover if so reconnect battery and walk away.
jib
Howard
CLS 500 / A 190
Light switches are also suspect on the w168
Ours stopped working , took it apart , inside was melted everywhere. Common problem apparently.
Triv
Bristol
Well built then.
:rolleyes:
Howard
CLS 500 / A 190
Probably not , I guess Lucas or Bosch need a talking to ?
